Blade MCX DSM2 issues
- 944storm
11 Mar 2013 12:03 #7638
by 944storm
Blade MCX DSM2 issues was created by 944storm
Hey everyone,
I've been using Deviation for the past month and have had great luck with my Walkera Helis. I was recently given a Blade MCX. It binds and flies without issue. My problem is I'd like to set the throttle curve to complex so I can hit the Throttle Hold before it crashes into something. Everytime I try to set that up, deviation freezes then restarts at model1. Can't seem to figure it out. Any help would be greatly appreciated.
Thanks all!
Thanks all!
11 Mar 2013 12:15 #7639
Replied by FDR on topic Blade MCX DSM2 issues
Which version do you use?
There is a workaround for the throttle hold: implement it with the safety feature of the channel config, i.e. set the safety switch to your throttle hold switch and the safety value to -100.
- 944storm
11 Mar 2013 12:18 #7640
by 944storm
Replied by 944storm on topic Blade MCX DSM2 issues
I am using 2.1.1. I will give that a try when I get home. Thank you for the quick response!
- 944storm
13 Mar 2013 21:58 #7714
by 944storm
That worked like a charm! Thank you!
Time to create page: 0.900 seconds
- Blade MCX DSM2 issues
