Blade MCX DSM2 issues
11 Mar 2013 12:03 #7638 by 944storm
Blade MCX DSM2 issues was created by 944storm
Hey everyone,
I've been using Deviation for the past month and have had great luck with my Walkera Helis. I was recently given a Blade MCX. It binds and flies without issue. My problem is I'd like to set the throttle curve to complex so I can hit the Throttle Hold before it crashes into something. Everytime I try to set that up, deviation freezes then restarts at model1. Can't seem to figure it out. Any help would be greatly appreciated.
Thanks all!
11 Mar 2013 12:15 #7639 by FDR
Replied by FDR on topic Blade MCX DSM2 issues
Which version do you use?
There is a workaround for the throttle hold: implement it with the safety feature of the channel config, i.e. set the safety switch to your throttle hold switch and the safety value to -100.
11 Mar 2013 12:18 #7640 by 944storm
Replied by 944storm on topic Blade MCX DSM2 issues
I am using 2.1.1. I will give that a try when I get home. Thank you for the quick response!
13 Mar 2013 21:58 #7714 by 944storm
That worked like a charm! Thank you! :-)
Time to create page: 0.392 seconds
