swash type
- 944storm
18 Mar 2013 21:06 #7902
by 944storm
swash type was created by 944storm
I've got a quick question. Why should we select none in the model setup for a fbl heli when it looks to be a 120 degree swash?
18 Mar 2013 21:10 #7903
Replied by FDR on topic swash type
Because the FBL unit does the CCPM not the tx...
- 944storm
18 Mar 2013 22:59 #7904
by 944storm
Replied by 944storm on topic swash type
OK, that makes sense. With that being the case, should I still use cyclic 1, 2, and 3 for the ele, ail, and pitch? Would it be better just to use the expo/Dr on that channel?
- coaster
19 Mar 2013 05:09 #7911
by coaster
Replied by coaster on topic swash type
Depends on the Flybarless System, e.g. the Align 3GX Needs 120 degree
swash type, the Microbest needs Swashtype none.
Cheers
Graziano
Cheers
Graziano
19 Mar 2013 05:22 #7912
Yes, certainly...
944storm wrote: OK, that makes sense. With that being the case, should I still use cyclic 1, 2, and 3 for the ele, ail, and pitch? Would it be better just to use the expo/Dr on that channel?
Yes, certainly...
- 944storm
19 Mar 2013 09:31 - 19 Mar 2013 09:32 #7920
by 944storm
I think I've got it figured out. Right now I'm flying smaller Walkera and Blade helis that have the rx/gyro together. Due to the fact the manual says nothing about saash type I'm going to just use expo/DR curves in that channel instead of cyclic mixing. Please correct me if I'm wrong. I'm trying to get a grasp of all the power this software has and how to use that power.
Thank You,
Sean
Thank You,
Sean
Last edit: 19 Mar 2013 09:32 by 944storm. Reason: wrong abbreviation
19 Mar 2013 10:05 #7922
I suggest you to read this article, it helps a lot:
www.deviationtx.com/forum/how-to/1226-ho...s-on-custom-firmware
Time to create page: 0.502 seconds
- swash type
