Devo 10 Illuminated Logo with a red LED
- sbstnp
24 Mar 2013 11:30 - 24 Mar 2013 12:50 #8036
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Devo 10 Illuminated Logo with a red LED was created by sbstnp
I was always bugged by the fact that my Devo 10 didn't have an LED showing if it's currently on or off.
Well, today I decided to mount my own. I only had green and red leds around and I decided on red since it looks better with the sticks and writing. The LED is a 5mm, I put a resistor in series and connected it to 3.3V.
There is enough space to mount around 3x5mm LEDs inside. Sorry, I didn't took pictures while mounting it.
EDIT:
Very important: I sanded the LED before mounting just to have nicely diffused light.
EDIT:
Devo 10 + 4in1
Last edit: 24 Mar 2013 12:50 by sbstnp.
- domcars0
24 Mar 2013 13:41 #8040
by domcars0
Replied by domcars0 on topic Devo 10 Illuminated Logo with a red LED
Very nice! I will do that, this afternoon as it's a rainy day here
Thank's
Thank's
- stevecox
- Keep swinging
24 Mar 2013 16:03 #8047
by stevecox
Adelaide
Replied by stevecox on topic Devo 10 Illuminated Logo with a red LED
SWEET, I have a Devo 10 on the way, this is gonna be first!
Man I lurve Deviation & the people
Adelaide
- Scream
27 Mar 2013 15:43 #8151
by Scream
Cheers!
-=S=-
Replied by Scream on topic Devo 10 Illuminated Logo with a red LED
SICKNESS!
well done bro! Pic added to heliporn library
Slightly related... I Was thinking team Deviation should make a sticker that's says Deviation to go right above where you've mounted your led... It would fit the theme too if only the "IA" and "DEVO 10" was transparent to let the LED through
A kit, with the LED and the sticker would be a great fund raiser for a well deserved development team (but that's a whole separate topic!).
Next time you take off her pants off (DEVO 10), please take a pic or 4 of the mod, I'd love to add this too!
Thanks for sharing!
-=S=-
Thanks for sharing!
-=S=-
Cheers!
-=S=-
- evo165
12 Jul 2013 10:13 #12209
by evo165
Replied by evo165 on topic Devo 10 Illuminated Logo with a red LED
Very NICE mod.
May i ask where do you connect the 3.3v power supply from?
I am using 3s lipo battery... Not sure if i can do the LED mod and connect it directly on the on/off switch.
Please advice sir...
- sbstnp
12 Jul 2013 14:11 #12217
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Replied by sbstnp on topic Devo 10 Illuminated Logo with a red LED
Same 3.3V we use for additional modules, together with GND of course. Because power comes directly from the board it lights up/turns off together with the transmitter.
Devo 10 + 4in1
- misterpepper
12 Jul 2013 15:53 - 12 Jul 2013 15:53 #12219
by misterpepper
Replied by misterpepper on topic Devo 10 Illuminated Logo with a red LED
I did similar to my 7e based on this post. I illuminated the little clear plastic "V" shape above the power switch using two 3mm LED's. Fitting the LED's was a tight fit, but the final result looks great. There is lots of info on the web for calculating the value of the current limiting resistor to use in line with the LED.
Last edit: 12 Jul 2013 15:53 by misterpepper.
- evo165
13 Jul 2013 02:09 #12222
by evo165
Please tell me which additional modules 3.3v you use? Or which is the exact parts that you tap the the wiring to?
I try open up my Devo 10 last night. I need to remove the middle small board in order for me to access the "Devo 10"... Man, There are many wires i really need to un-plug off from the small board.
- sbstnp
13 Jul 2013 07:05 - 13 Jul 2013 07:06 #12226
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
The pins are listed in the additional module installation documents. I use basically the debug header to source power (yellow circle).
Thos wires you see are clearly labeled and mistakes should not be possible. But, before I disconnect anything new to me I take a picture. Simple but very effective way of remembering the initial state of what I'm gonna disassemble.
evo165 wrote: Please tell me which additional modules 3.3v you use? Or which is the exact parts that you tap the the wiring to?
Devo 10 + 4in1
Last edit: 13 Jul 2013 07:06 by sbstnp.
- SadSack
15 Jul 2013 12:32 #12251
by SadSack
Replied by SadSack on topic Devo 10 Illuminated Logo with a red LED
- Timmz32
05 Sep 2017 07:41 #64187
by Timmz32
Replied by Timmz32 on topic Devo 10 Illuminated Logo with a red LED
Sadsack how do you change out the deviation logo?
- sbstnp
27 Sep 2017 02:02 #64682
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
That was a loooooong time ago man
Devo 10 + 4in1
Time to create page: 0.917 seconds
- Devo 10 Illuminated Logo with a red LED
