WTF! HELP!
- Scream
27 Mar 2013 13:20 #8141
by Scream
Cheers!
-=S=-
WTF! HELP! was created by Scream
Hi!
Please help!
I connected my devo10 through USB to grab some models and then I turned off the devo.
When I turn it back on, I can only load the first model!! All other entries are blank in the "load" options.
If I reconnect the Tx to USB then I can see that the configs are still there but they don't show in the Model setup ->Load options (only #1 shows!)
Please help me recover my models!
thanks!
-=S=-
Please help!
thanks!
-=S=-
Cheers!
-=S=-
27 Mar 2013 13:42 #8142
Replied by FDR on topic WTF! HELP!
Did you disconnect the USB drive before pulling out the USB plug?
Did you use drag-and-drop to copy them there? Because then they might be shortcuts only. Check the extensions.
- Scream
27 Mar 2013 13:51 #8143
by Scream
Cheers!
-=S=-
Replied by Scream on topic WTF! HELP!
Hi FDR,
I just turned the devo off when I finished coping the files from the TX to the computer.
The files I copied are good, the files in the devo are also good, but when I go to model munu -> model setup -> load : only the first file shows and there are no other entries at all on the screen.
If I reconnect the devo, the files are still in there and can be opened and view by wordpad.
Cheers!
-=S=-
Cheers!
-=S=-
Cheers!
-=S=-
27 Mar 2013 14:27 - 27 Mar 2013 14:28 #8145
Replied by vlad_vy on topic WTF! HELP!
I think these invisible files have extension *.txt, that hidden by Explorer (Hide extension for known file types).
Check that files are modelXX.ini, not modelXX.ini.txt
Last edit: 27 Mar 2013 14:28 by vlad_vy.
- Scream
27 Mar 2013 14:48 #8146
by Scream
Cheers!
-=S=-
Hi Vlad,
Unfortunately the files are indeed .ini and windows identifies them as "configuration settings".
OH!
It turns out, that before I have 2 coffees and drop a deuce, i'm pretty retarded in the morning.
I had accidentally moved, rather than copy model2. When I replaced it we're back to normal!
Sorry for the false alarms, and thanks gents for the quick replies!
Have a good day!
-=S=-
OH!
Have a good day!
-=S=-
Cheers!
-=S=-
- JJ1984
27 Mar 2013 14:53 #8147
by JJ1984
Replied by JJ1984 on topic WTF! HELP!
Hmmm, I cant help but feel a tiny bit responsible scream.
But at least you have sorted it out.
Time to create page: 0.201 seconds
- WTF! HELP!
