Trying to set up a Mini CP. Values have changed!
27 Mar 2013 23:13 #8161 by JJ1984
I have tried to download MINI CP configs off here but not had much luck with them as they seem aimed more for 3D. I wanted my tame settings I used with the Devo OE FW
Anyway i got the manual out and started to create a new model on my Devo TX based on standard settings so i can work on it from there but I came across a stumbling block.
Where Devention values are 0% to 100% the values Deviation have now are -100 to +100 So i am slightly confused as to what values to input.
Some values in devention fw are -100 to +100 so I take it these values are the same??
Can anyone enlighten me.
thank you
28 Mar 2013 03:42 #8180 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Trying to set up a Mini CP. Values have changed!
From Hexperience's FBL how-to (well worth a read)
** If your heli manual uses 0%-100% you will need to convert those to -100 to +100 values. So take the value X 2 -100. ie if your manual says set the "whatever" to 30% then 30x2-100 = -40 **
So say you need a value for an 80% throttle;
(80 x 2) - 100
= 160 - 100
= 60
28 Mar 2013 08:09 #8184 by JJ1984
I have just read that.
Gosh im prob going to need a week to adjust my TX and learn the new setup.
Thanks for that tho that makes complete sense now after reading Hexperience FBL How to.
Time to create page: 0.618 seconds
