Blade 130x
07 Apr 2013 01:10 #8666 by markosgt
Blade 130x was created by markosgt
Hello everyone.
Im waiting for my new blade 130x and i want to use it with my devo8s.
I searched and found most about deviation and th ini file for the 130x.
What i didnt find is the way to bind the devo8s with the 130x.
I read somewhere this...
Here are the steps on how to bind to DSM 2:
Prerequisite: Transmitter powered off, receiver/model powered off.
1. Power on transmitter.
2. Power on model (plug in battery). Will be in bind mode.
3. Go to transmitter and select bind.
4. Remove battery from model.
5. Plug in battery to model again.
6. Once model is powered up, the model will be bound.
If the transmitter is powered off and on again, this whole process needs to be repeated again.
Is this correct and if yes do i have to make the same thing everytime i change battery?
Thank you in advance.
07 Apr 2013 18:13 - 07 Apr 2013 18:15 #8695 by markosgt
Replied by markosgt on topic Blade 130x
Please someone with a blade 130x could help?
Can i use fixed id with the blade 130x?
Last edit: 07 Apr 2013 18:15 by markosgt.
07 Apr 2013 18:17 #8697 by domcars0
Replied by domcars0 on topic Blade 130x
Reading the manual you will see that you have to use fixed id :huh:
09 Apr 2013 11:27 #8781 by Wene001
Replied by Wene001 on topic Blade 130x
Power one 130x Led goes flashing
Power on TX (Fixed ID and DSM2 or DSMX ) and press the Bind Button - the Led goes solid
Have fun
20 Jun 2013 16:24 #11169 by Scream
Replied by Scream on topic Blade 130x
I switched over to DSMx and it binds 100% everytime.
Just change the setting in the model setup menu once, rebind once and you're good to go, and go and go...
Cheers!
-=S=-
Cheers!
-=S=-
Time to create page: 0.192 seconds
