Timer with THR & T-Cut still counts irrespective
- stevecox
- Keep swinging
07 Apr 2013 20:37 #8718
by stevecox
Adelaide
Timer with THR & T-Cut still counts irrespective was created by stevecox
I have just noticed, not sure if it was there before or on the D8, but on my D10 (ver 3.0) if I have a timer using THR input, the THR having a T-Cut switch setup to say Rud_DR0, the timer counts whether the T-Cut is active or not when I move the throttle stick. The T-Cut setup works correctly otherwise to cut/keep throttle dead when active - ie no output when the stick is moved etc, in the mixer screen and on the rx side. Seems to be a timer thing ignoring a T-Cut switch if in use on THR for example. This is on countdown and stopwatch. If this is meant to happen is there a way for it not to, have I missed something perhaps?
Adelaide
- cmpang
08 Apr 2013 01:26 - 08 Apr 2013 01:31 #8725
by cmpang
there has been some discussion on this topic and was told it is just the way it should be.. so just take it do it the other way to get it around..
www.deviationtx.com/forum/6-general-disc...by-the-mapping-logic
Replied by cmpang on topic Timer with THR & T-Cut still counts irrespective
stevecox wrote: I have just noticed, not sure if it was there before or on the D8, but on my D10 (ver 3.0) if I have a timer using THR input, the THR having a T-Cut switch setup to say Rud_DR0, the timer counts whether the T-Cut is active or not when I move the throttle stick. The T-Cut setup works correctly otherwise to cut/keep throttle dead when active - ie no output when the stick is moved etc, in the mixer screen and on the rx side. Seems to be a timer thing ignoring a T-Cut switch if in use on THR for example. This is on countdown and stopwatch. If this is meant to happen is there a way for it not to, have I missed something perhaps?
Last edit: 08 Apr 2013 01:31 by cmpang.
08 Apr 2013 04:06 #8726
Replied by FDR on topic Timer with THR & T-Cut still counts irrespective
Use the channel value Ch3 (or Ch1 depending on the protocol) to start the timer...
- stevecox
- Keep swinging
08 Apr 2013 04:32 #8727
by stevecox
Adelaide
Replied by stevecox on topic Timer with THR & T-Cut still counts irrespective
cmpang okay cool, FDR sweet that works perfect - I should've dug a bit more in the forum
Adelaide
Time to create page: 0.040 seconds
- Timer with THR & T-Cut still counts irrespective
