Throttle lower limit stuck at -95%
- myxiplx
26 Apr 2013 19:04 - 26 Apr 2013 19:05 #9239
by myxiplx
Throttle lower limit stuck at -95% was created by myxiplx
Hi folks,
I've been running Deviation this week, it's been going well but today I edited the throttle values on the transmitter, trying a couple of things:
My throttle curve was set to -100,0,50,100,100,100,100 and I wanted to reduce the upper limit to 90. First of all I tried reducing the scale to 90, that worked for the upper limit, but affected the lower limit too.
So I went back in, put the scale back to 100, and edited the points manually, setting the throttle curve to -100,0,50,90,90,90,90.
What I've noticed now is that the low point on the throttle always outputs -95, and I can't find any way to get it down to -100. The settings on the transmitter appear correct, and the .ini file seems ok too. Could somebody take a look and let me know where I'm going wrong.
Cheers,
Ross
Cheers,
Ross
Last edit: 26 Apr 2013 19:05 by myxiplx. Reason: More accurate title.
- myxiplx
26 Apr 2013 19:14 #9240
by myxiplx
Replied by myxiplx on topic Throttle lower limit stuck at -95%
Another couple of things I've noticed:
For the first set of throttle points (Normal flight mode), if I go to edit the 7 points, I scroll down to select the point number, and press the Right control to scroll through, the sequence skips 3 and 4, it goes 1, 2, 5, 6, 7. Only after I go backwards through points 5,4,3 does it behave normally and let me access all 7 points with both the Left and Right cursor controls.
Also, the second FMODE1 throttle curve keeps reverting back to LINKED. I can set it back to 7POINT and save the setting, and I can check it in the .ini file, but every time I go to the transmitter to check the settings it says LINKED again.
Ross
Ross
26 Apr 2013 19:33 #9242
Replied by FDR on topic Throttle lower limit stuck at -95%
Throttle curves look ok.
Have you calibrated your sticks?
- myxiplx
26 Apr 2013 19:57 #9245
by myxiplx
Thanks, calibrating the sticks corrected the lower limit issue, strange they'd suddenly lost that, but an easy fix
Any ideas on why FMODE1 keeps showing as linked in the GUI?
Time to create page: 0.697 seconds
- Throttle lower limit stuck at -95%
