Throttle lower limit stuck at -95%
26 Apr 2013 19:04 - 26 Apr 2013 19:05 #9239 by myxiplx
Throttle lower limit stuck at -95% was created by myxiplx
Hi folks,
I've been running Deviation this week, it's been going well but today I edited the throttle values on the transmitter, trying a couple of things:
My throttle curve was set to -100,0,50,100,100,100,100 and I wanted to reduce the upper limit to 90. First of all I tried reducing the scale to 90, that worked for the upper limit, but affected the lower limit too.
So I went back in, put the scale back to 100, and edited the points manually, setting the throttle curve to -100,0,50,90,90,90,90.
What I've noticed now is that the low point on the throttle always outputs -95, and I can't find any way to get it down to -100. The settings on the transmitter appear correct, and the .ini file seems ok too. Could somebody take a look and let me know where I'm going wrong.
File Attachment:
File Name: model1_2013-04-26.ini
File Size:8 KB
Cheers,
Ross
Last edit: 26 Apr 2013 19:05 by myxiplx. Reason: More accurate title.
26 Apr 2013 19:14 #9240 by myxiplx
Replied by myxiplx on topic Throttle lower limit stuck at -95%
Another couple of things I've noticed:
For the first set of throttle points (Normal flight mode), if I go to edit the 7 points, I scroll down to select the point number, and press the Right control to scroll through, the sequence skips 3 and 4, it goes 1, 2, 5, 6, 7. Only after I go backwards through points 5,4,3 does it behave normally and let me access all 7 points with both the Left and Right cursor controls.
Also, the second FMODE1 throttle curve keeps reverting back to LINKED. I can set it back to 7POINT and save the setting, and I can check it in the .ini file, but every time I go to the transmitter to check the settings it says LINKED again.
Ross
26 Apr 2013 19:33 #9242 by FDR
Replied by FDR on topic Throttle lower limit stuck at -95%
Throttle curves look ok.
Have you calibrated your sticks?
26 Apr 2013 19:57 #9245 by myxiplx
Thanks, calibrating the sticks corrected the lower limit issue, strange they'd suddenly lost that, but an easy fix :)
Any ideas on why FMODE1 keeps showing as linked in the GUI?
Time to create page: 0.584 seconds
