Range on flysky module
27 Apr 2013 17:47 - 27 Apr 2013 17:49 #9280 by IMback!
Range on flysky module was created by IMback!
I just solderd a flysky module recoverd form a toy v911 tx into my devo 7e it works but even at "150mW" the rage is realy short (tested with a v911) not even 5 meters, what could have gon wrong? i placed the antenna next to the devo antenna into the antenna stub if that makes any diffrence
EDIT: version is deviation 3.0.0
Last edit: 27 Apr 2013 17:49 by IMback!.
27 Apr 2013 21:02 - 27 Apr 2013 21:03 #9283 by RandMental
Replied by RandMental on topic Range on flysky module
Your problem might be that the two antennas affect each other. Try removing the Flysky antenna and rather position it vertical in the corner of and against the battery compartment - that way it is away from other conductive items and your hands wont shield it.
Last edit: 27 Apr 2013 21:03 by RandMental.
28 Apr 2013 11:43 - 28 Apr 2013 11:46 #9304 by IMback!
Replied by IMback! on topic Range on flysky module
Tryed moving the antenna dosent help :( i even tryed it with the module and antena ouside of the tx it dose maybe 15m like that so its still realy bad, also devo is negativly affected too it dosent do more than 20 meters anymore (with my super cp). i double checked all and then i redid all the joints dosent help, looks like im out of a tx :(.
EDIT: I just examined my soldering iorn an descoverd that it leaks voltage.. tip to ground is about 1mv could this have broken somthing in the tx?
Last edit: 28 Apr 2013 11:46 by IMback!.
28 Apr 2013 12:20 #9306 by mono
Replied by mono on topic Range on flysky module
1 millivolt won't do anything, what did you measure that with?
Do you have a reasonably high powered magnifier so you can inspect all the solder work more closely? It's surprising what the human eye can't detect regardless of how good your eyesight may be.
By the way, did you remove the rf shield from the 7E module to do the diode mod? As you say range is short on that also, there may be a problem in that area.
28 Apr 2013 12:53 - 28 Apr 2013 12:55 #9309 by IMback!
I converted units wrong its acutauly 10mv as mesured by my multimeter sadly i dont have a maginfying lense.
EDIT: i didnt modyify the devo module at all its still just 7mW
Last edit: 28 Apr 2013 12:55 by IMback!.
28 Apr 2013 16:14 #9318 by IMback!
I removed the flysky module, devo works fine again... so no new tx after all. Im thinking of buying a new module (maybe i damaged it?).
28 Apr 2013 22:48 #9326 by mono
That's good, at least you know the 7E is still ok.
As to whether the 911 module has developed a fault, it may be safer to just assume that it has. The A7105-D03 module is only ~$15, so you might be able to get one of those to use instead.
Otherwise you could wire up the 911 module to the tx it was removed from and see what happens, at least it should indicate if that is the source of the problem.
Time to create page: 0.399 seconds
