Tried to revert back but...
01 May 2013 14:45 #9450 by Blayd
Tried to revert back but... was created by Blayd
When I did, I now get a "version error" in the display on a Devo 8. ( not 8S )
It came with Deviation installed, I'm not flying anything but 802Rx's.. so I want it back to Devention.
I've tried twice now, and after the Dfuse software has given me the " Success " for both firmware upgrade, and Library upgrade, when I quit the Defuse software, the Tx flashes " version error.
I could use some help.
Thanks.
Devo 8S
Trex500ESP
Trex500ESP (Belted tail)
HC500SE
Trex700N2E
01 May 2013 14:48 #9451 by RandMental
Replied by RandMental on topic Tried to revert back but...
Which Deviation firmware are you using and which version of DfuSe?
01 May 2013 15:12 - 01 May 2013 15:20 #9452 by vlad_vy
Replied by vlad_vy on topic Tried to revert back but...
Possible it is version A and B (100mW and 10mW)? You can find original version on sticker inside battery box.
Last edit: 01 May 2013 15:20 by vlad_vy.
01 May 2013 15:36 #9453 by Blayd
Replied by Blayd on topic Tried to revert back but...
I dont know what version of Deviation it was running.
I cant see the version because now when I turn on the Tx, it just flashes the screen with "version error" dispayed.
There is no sticker in the battery compartment with a version number. Only a sticker that tells you to use 4 NiCad or 4 dry batts.
The firmware I downloaded was the 100mw version, I'll try the 10mw version...
It never occured to me to ask if this was the 10mw or 100mw version Tx. I thought they were all capable of 100mw.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
01 May 2013 15:49 #9454 by Blayd
OK, I just upgraded the devention software to the 10mw version and it went fine. Thanks for all the help and suggestions.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
01 May 2013 16:03 #9455 by Blayd
I wish I had known this was a 10mw version.. I guess buyer beware.
Since I wont fly my bigger birds on this, ( not on 10mw ) I guess I might go back to deviation and play around with it more.
Thanks again for the help all....
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
01 May 2013 16:10 #9456 by PhracturedBlue
Replied by PhracturedBlue on topic Tried to revert back but...
Note that in Deviation, your radio will be 100mW. The only difference between 10mW and 100mW radios is in the internal identification bit which Deviation igonres
01 May 2013 16:19 #9457 by Blayd
So buy using the latest version of Deviation, It will allow me to run at 100mw?
I fly 700's and the guy who sold me the Devo 8 didnt bother to tell me it was the 10mw version. Yeah, with years on the 2801Pro, you'd think I would have learned, but I assumed all the Devo Tx's were now 100mw capable.
Live and learn.
I have an 8S also, new, and was planning on using the 8S as my main Tx, with the 8 as a back up.
I will go back to the latest version of Deviation, just have to learn how to do this now..LOL
Thanks for any and all help.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
01 May 2013 20:21 - 01 May 2013 20:30 #9460 by RandMental
Have you tried the updates on this site under Downloads\Miscelaneous?
Last edit: 01 May 2013 20:30 by RandMental.
01 May 2013 20:30 #9461 by Blayd
Thanks for the repy.
I might.
Right now, I have 3.0 installed, and am lost like an idiot.
I'm having a time trying to figure out how to set up swashmix and pitch curves for my FB heli's. :blink:
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
01 May 2013 20:35 - 01 May 2013 20:38 #9462 by RandMental
If you switch to the Standard mixer/GUI it might be easier and closer to what you were used to on the Devention/2801 firmware. Also see Hexperience`s sticky on how to configure for Deviation for FBL heli`s
Last edit: 01 May 2013 20:38 by RandMental.
01 May 2013 20:50 #9464 by Blayd
Yeah, I've been looking at the "standard" GUI, might be how I'm going to gwt this set up.
Thanks.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
Time to create page: 0.707 seconds
