Where/how to get devo 12S spares ?
18 May 2013 17:26 - 18 May 2013 17:30 #10102 by th9xer
Where/how to get devo 12S spares ? was created by th9xer
So I have decided to graft part of the rear case from a JR transmitter to the back of a Devo 12S, reason being to get a modular Devo 12S.
I already have a JR case rear to sacrifice, but I want a spare Devo 12S case rear, so a) I am covered if I mess it up, and b) If I ever want to sell it I can put it back to stock.
I have Skype'd Walkera, the messages queue and never go anywhere, I have tried MSN only to be told the (Walkera) profile doesn't exist, I tried emailing the This email address is being protected from spambots. You need JavaScript enabled to view it. address from the website only to have it bounce, and I have messaged them on their own website without success.
What's a guy to do, any ideas ?
Last edit: 18 May 2013 17:30 by th9xer.
20 May 2013 10:44 #10139 by Hexperience
Replied by Hexperience on topic Where/how to get devo 12S spares ?
I have been looking to use modules as well but my main problem is that the devo 12 is only running on 3.7 volts. Are you going to use 1 higher voltage battery with a drop down to power the devo12 or an additional battery just for the modules?
21 May 2013 21:57 #10215 by Wene001
Replied by Wene001 on topic Where/how to get devo 12S spares ?
21 May 2013 23:21 #10216 by Hexperience
I have thought about that but I think it better to run a 2 cell and a 4v ubec to run the radio... ???
Would uping the voltage off of a 1 cell cause it to drain reallh fast?
22 May 2013 00:38 #10219 by th9xer
Replied by th9xer on topic Where/how to get devo 12S spares ?
I was just going to roll my own modules using the Spektrum module case ( www.spektrumrc.com/Articles/Article.aspx?ArticleID=2126 ) and the various modules that people are already connecting to the Devo.
04 Jun 2013 17:24 #10560 by th9xer
I got a hold of Walkera in the end, I used Skype. Unfortunately they don't keep case rears on stock and had no date for when they would have them in. I think that may have been the polite way of saying "never".
Worse than that my idea is flawed in that most of the additional modules require 6 connections: DI DO CLK CS +ve GND, and standard external module connections are only 5 pin. Bit of an oversight on my half :(
I suppose I could combine pins with level shifting etc. back to the drawing board.....
Time to create page: 0.301 seconds
