Devo 10 with A7105 range problem
- sublime
01 Jun 2013 15:24 - 02 Jun 2013 11:24 #10482
by sublime
Devo 10 with A7105 range problem was created by sublime
I just soldered my A7105 from Aliexpress to my Devo 10. I used this tutorial:
Flysky/Hubsan/turnigy module with pics : devo 8S
I am using Deviation 3.0 and activated the A7105 in the tx.ini. I tried to bind the Devo with my V929 but it won't work. Also everytime I push "bind" or "re-init" in the model configuration the Devo just freezes completely.
I have to remove the batteries to shut it down.
Anyone has a suggestion what went wrong?
Last edit: 02 Jun 2013 11:24 by sublime.
- 8987846
02 Jun 2013 09:08 #10494
by 8987846
Replied by 8987846 on topic Devo 10 with A7105 freezes on binding
i was going to do this mod until i see this....
- sublime
02 Jun 2013 11:22 #10497
by sublime
Replied by sublime on topic Devo 10 with A7105 freezes on binding
So just a short update. I tried Deviation 2.1.1 and the last nightly build (v3.0.0-fd346b). With this versions the Devo binds with the V929 and also doesn't freeze anymore, when I push "bind" or "re-init".
But now there is another problem - the range. Even on 150mW I sometimes only get about 3 or 4 meters of range. I read this could be a problem with a fixed id that is 6 characters long, so I changed to 1111. Unfortunately this only helps occasionally. Sometimes the range is totally ok, sometimes it's just about 3-4 meters again. So in my opinion the fixed id isn't the only thing that influences this problem.
- dc59
03 Jun 2013 00:11 #10510
by dc59
Replied by dc59 on topic Devo 10 with A7105 freezes on binding
Did you wire "RXEN"(PIN8) to GND?
If not , please try it!
- sublime
03 Jun 2013 18:25 #10526
by sublime
It seems like this fixed the problem. But as this was just occasionally I need to do some more testing to be sure.
Whats the meaning of RXEN and GND and all the others? Is there an explanation anywhere? I also connected PIN9 with PIN1. Is that right?
Thank you so far!
Thank you so far!
- dc59
- 8987846
03 Jul 2013 03:36 #11798
by 8987846
Replied by 8987846 on topic Devo 10 with A7105 range problem
i am also getting this problem, the screen freeze when i select "bind".
i have already edited tx.int. but i did not connect pin 9 to pin 1....
i also do not understand how to connect pin 8 to GND? where is GND?
i am not sure what is missing here, please help.
Thanks in advance!
Thanks in advance!
- 8987846
03 Jul 2013 04:28 #11799
by 8987846
already binded.... i connected pin 8 to pin 3. now it all fixed! thanks
- RandMental
05 Jul 2013 19:59 - 05 Jul 2013 20:22 #11977
by RandMental
Replied by RandMental on topic Devo 10 with A7105 range problem
Last edit: 05 Jul 2013 20:22 by RandMental.
- goebish
- NRF Weirdo
04 Aug 2013 22:33 #12760
by goebish
Replied by goebish on topic Devo 10 with A7105 range problem
Documentation should be updated because that's what Gents will read when installing a module
www.deviationtx.com/repository/func-startdown/23/
- matrixFLYER
06 Sep 2013 16:06 - 06 Sep 2013 16:06 #13612
by matrixFLYER
This is a modded documentation.
Replied by matrixFLYER on topic Devo 10 with A7105 range problem
goebish wrote: Documentation should be updated because that's what Gents will read when installing a module
Last edit: 06 Sep 2013 16:06 by matrixFLYER.
Time to create page: 0.191 seconds
- Devo 10 with A7105 range problem
