Should i use lipo in devo 10?
10 Dec 2017 16:57 - 11 Dec 2017 13:25 #66429 by Fer
Replied by Fer on topic Should i use lipo in devo 10?
Ok, i will purchase a 2s LiFe then, and just test it to see at what voltage the tx will turn off. It it works ok until 5volts it will very good. Thank you.
Last edit: 11 Dec 2017 13:25 by Fer.
10 Dec 2017 20:16 - 10 Dec 2017 20:17 #66430 by sbstnp
Replied by sbstnp on topic Should i use lipo in devo 10?
I would get a 3S LiFE instead of a 2S. Hobbyking makes one that fits perfectly. Actually I think they make 2, one 1800mah and one 2100mah, good price too.
Also, DO NOT USE 150mw if you want decent battery life, that power setting HALVES the battery life for a marginal range improvement.
As a general rule, this is how my power settings are used:
* 100mw - 5, 6, 7" quads, flying behind obstacles sometimes, can't take chances with these.
* 30mw parkflyer planes, line of sight or indoor in parking lots or similar.
* 10mw indoor flying.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 10 Dec 2017 20:17 by sbstnp.
11 Dec 2017 05:19 #66432 by Gerry
Replied by Gerry on topic Should i use lipo in devo 10?
I am not an electronics guru by any means, but there are many on these forums that would say any voltage over what is required by the voltage regs in the devo's is wasted in heat and puts electronic components at risk. Please refer to the fourth & sixth post on page 1 of this thread by PB.
FFS (Forever Fixing Stuff)
11 Dec 2017 06:29 #66433 by sbstnp
Because it's much easier to find a shape that fits. Simple as that.
Gerry wrote: I am not an electronics guru by any means, but there are many on these forums that would say any voltage over what is required by the voltage regs in the devo's is wasted in heat and puts electronic components at risk. Please refer to the fourth & sixth post on page 1 of this thread by PB.
Devo 10 + 4in1
Spektrum Dx9
11 Dec 2017 08:15 #66434 by Gerry
But Fer has already stated that he has modified the battery compartment and installed a BEC and switch. Will the battery you suggest still be a perfect fit?
11 Dec 2017 08:30 #66435 by sbstnp
I have the 1800mah 3S and it fits perfectly in the stock compartment.
Gerry wrote: But Fer has already stated that he has modified the battery compartment and installed a BEC and switch. Will the battery you suggest still be a perfect fit?
Devo 10 + 4in1
Spektrum Dx9
11 Dec 2017 08:42 #66436 by Gerry
That does not answer the question asked.
11 Dec 2017 09:39 #66438 by sbstnp
Gerry wrote: That does not answer the question asked.
Are you in need of a new battery? If not, stay out of the discussion, I'm sure Fer can speak for himself.
Devo 10 + 4in1
Spektrum Dx9
11 Dec 2017 11:39 #66440 by Gerry
Wow. I thought the forums were a place for discussions, sharing knowledge, and learning.
Clearly I am incorrect in this assumption. Can you tell me where to delete my account from this website?
11 Dec 2017 12:04 #66441 by FDR
Replied by FDR on topic Should i use lipo in devo 10?
Easy Gents!
C'mon, what's all this fuzz about an off topic discussion? :blink:
11 Dec 2017 19:09 #66452 by sbstnp
Apologies, I overreacted :unsure:
Devo 10 + 4in1
Spektrum Dx9
19 Nov 2020 11:55 #77032 by Konsta
Replied by Konsta on topic Should i use lipo in devo 10?
Well I tried plugging in my fully charged 7,4 V 2000 mah battery and it showed only 1/4 of battery. Plugging in my fully charged 9,6 V 1600 MAH battery and it shows 3/4 battery. So I think 3s lipo will show full battery? On a fully charged 8,4 V NIMH it didn't even go on.
19 Nov 2020 15:52 - 19 Nov 2020 15:52 #77033 by Fer
So long ago i changed to using 2s battery, i can't really remember what i had to do, but i believe i changed a couple of lines in tx.ini file in order to work.
batt_alarm=7100
batt_critical=7000
Forgive me if i am mistaken, try these values for a 2s Lipo battery and see if it works. (Use notepad++ for opening the .ini file, the windows notepad corrupts the file)
Last edit: 19 Nov 2020 15:52 by Fer.
19 Nov 2020 17:16 #77034 by Konsta
Fer wrote: So long ago i changed to using 2s battery, i can't really remember what i had to do, but i believe i changed a couple of lines in tx.ini file in order to work.
batt_alarm=7100
batt_critical=7000
What are you talking about?
19 Nov 2020 21:01 #77037 by propnut
Replied by propnut on topic Should i use lipo in devo 10?
He is talking about changing the low voltage alarm to match the voltages present on a 2S lipo. By default the system is set for 9.6v and so if you use a 2S you will constantly be getting a low voltage alarm. Personally I use a 3S LiFE which lasts for ages.
19 Nov 2020 21:03 #77038 by Konsta
propnut wrote: He is talking about changing the low voltage alarm to match the voltages present on a 2S lipo. By default the system is set for 9.6v and so if you use a 2S you will constantly be getting a low voltage alarm. Personally I use a 3S LiFE which lasts for ages.
So you can change it? Where exactly in the settings?
22 Nov 2020 11:38 #77047 by propnut
In the tx.ini file
current_model=1
language=0
music_shutdown=1
mode=2
brightness=10
contrast=5
volume=10
audio_vol=0
vibration=1
power_alarm=0
batt_alarm=6300
batt_critical=3900
batt_warning_interval=30
splash_delay=35
23 Nov 2020 12:25 #77048 by Mack775
Replied by Mack775 on topic Should i use lipo in devo 10?
People might disagree with me but I have several devo 10 and run them all on turnigy 3 cell 2.2 and 2.65. Two are pretty old.And all but 1 have 4 in 1 module,except 1 still use devention for qr x350 pro. But I quess use them at your on risk.
16 Feb 2022 17:28 #77845 by jfitz66
Replied by jfitz66 on topic Should i use lipo in devo 10?
I have several Devo10's and have the gain set to the highest. I've never had an issue using 3s 2200mh lipo batteries. Always fully charged before I leave for the day. I wonder morenabout the receivers. I currently use 4 or 5 cell nimh. I'd like to switch to LiFe but wonder if I should use a bec set to 6 volts
Time to create page: 0.208 seconds
