Left gimbal (THR / RUDD) erratic output
- Martian
08 Jun 2013 13:45 #10713
by Martian
HELIs: V929, MCX2, MSR, Nano CP X
TX: Devo 10 (Deviation 3.0.0)
Left gimbal (THR / RUDD) erratic output was created by Martian
Last night I attempted the A7105 module installation. I had an issue where the vibration motor ran constantly but that resolved itself once I selected the Flysky module (see my other thread on that). The A7105 appears to be working normally and I can bind and control my V929. The problem is that last night the Rudder output was erratic (left / right on left gimbal). Now this morning the Throttle gimbal is showing the same erratic output in addition to the rudder. In the channel output monitor the levels for Ch4 (Rudder) and now Ch3 (throttle) dance up and down by about 20-40. I've tried calibration but all that really does is center the range that the levels are dancing around at 0.
Obviously it's impossible to fly anything in this state. I thought maybe I had a bad pickup on the rudder but now that the throttle is doing it as well I really don't know what to think. Any help or suggestions of what to try would be greatly appreciated!
08 Jun 2013 13:49 #10714
Replied by FDR on topic Left gimbal (THR / RUDD) erratic output
Check the plugs of the pots on the PCB for any contact problems first...
- Scream
08 Jun 2013 14:16 #10717
by Scream
Cheers!
-=S=-
Replied by Scream on topic Left gimbal (THR / RUDD) erratic output
Hiya!
I was having the same behavior, but everywhere.... try loosing the gymbal springs!
Cheers!
-=S=-
Cheers!
-=S=-
Cheers!
-=S=-
- Martian
08 Jun 2013 20:19 #10724
by Martian
I assume you mean the 3 wire (red, yellow, black) plugs that plug into the main board? If so, I've unplugged, checked, cleaned with alcohol, plugged, checked and double checked at least 10 times. If you mean something else then please explain (I'm not always the sharpest tool in the shed)
I'll give that a shot, I don't see how the springs could cause +/- 40% variance I'm seeing but at this point I'll try anything.
I checked the channel monitor with the stick inputs (left stick) unplugged and neither channel moved at all so the issue certainly appears to be in the sticks / pots and not in the main board.
Replied by Martian on topic Left gimbal (THR / RUDD) erratic output
FDR wrote: Check the plugs of the pots on the PCB for any contact problems first...
Scream wrote: Hiya!
Cheers!
-=S=-
- Martian
09 Jun 2013 01:46 #10728
by Martian
Well it certainly isn't the spring tension. In fact it appears I was wrong in my previous post. It doesn't appear to be the pots after all. I removed the gimbals and tested the potentiometers with my multimeter and they are dead on and the resistance isn't fluctuating at all on either of them.
I decided to remove the A7105 module and eliminate that as a possible factor (I also disabled it in the .ini file) Unfortunately that didn't solve the problem. I've inspected the connections to the pots and inspected and cleaned both sides of the board. There are no visible shorts or anything like that.
I'm really at a loss. I'm probably going to try flashing back to the stock firmware and see what that does although I really don't have high hopes.
Any thoughts / suggestions would be greatly appreciated.
09 Jun 2013 03:56 #10729
Replied by PhracturedBlue on topic Left gimbal (THR / RUDD) erratic output
1) see if you still have an issue with Stock. this will eliminate Deviation as the cause
2) unplug the gimbals and see if you still see an issue (with stock firmware) with them unplugged (I'm not actually sure what you'll see but I don't think it will be jittery. This would hopefully isolate the problem to on the motherboard vs off.
When you get jittery values, it would normally indicate cross coupling into the adc (or it hasn't been configured properly, which shouldn't be the case here)
If nothing else, compeletly remove the main board and use a can of compressed air to blow both sides down. Perhaps you have a piece of silder or wire somehwere that is shorting out. The problems you had earlier with the A7105 certainly lead in this direction.
- Martian
10 Jun 2013 00:42 #10748
by Martian
Thanks for the response PB. I did flash back to stock however I couldn't find any sort of channel monitor to know if the problem exists there or not and I don't have any helis I can fly with the stock firmware. Do you know if there is a channel monitor of something similar in the stock firmware? I flashed back to Deviation 3.0.0 and the problem was still there.
Tonight I removed the main board and thoroughly cleaned and inspected it and blew it off with compressed air. I checked that all connections were tight when re-assembling. I performed a calibration but still the issue persists.
The Rudder channel is the worst however the throttle is still moving around as well without input from the stick.
It's like the center point is moving. Stick movement clearly registers but I can't go all the way to 100 (for rudder), full right is like 80 and I reach -100 well before the stick is fully left. The "center" typically shows anywhere from -40 to around 0 but mostly between -20 to -25. The throttle has a similar issue only reaching about 80 on the high end and reaching -100 before it should on the low end. Keep in mind this is seconds after a full calibration. I can see it start centered at 0 and sporadically "drift" away. Makes we wonder if I have a bad ground somewhere that is floating up a little or perhaps weak power that is being pulled down? I have swapped batteries (fully charged NiMH) to no affect other than the voltage displayed on the screen being higher...
Thanks again for the help with this issue. I really love Deviation and the Devo 10 and I hate not being able to fly or even practice on Phoenix. I was able to re-install the A7105 into the V929 remote so at least I can fly that. If I do even attempt the mod again I get one from Ali Express.
- Martian
11 Jun 2013 21:24 #10808
by Martian
I flashed back to stock again and this time found the monitor (don't know how I missed it before). Anyway, the problem is still present on stock so it is definitely not related to Deviation (not that I ever thought it was).
11 Jun 2013 21:37 #10809
Have you tried it with the gimbals unplugged, or reversed? It would be useful to confirm the issue in on the board.
Also, what are you using as a battery? The A/D circuitry is potentially very sensitive to the stability of the reference volatge.
- Martian
12 Jun 2013 01:01 #10814
by Martian
I tried it with gimbals plugged and unplugged and I've actually taken out the pots and measured them with a multimeter. Issue is still present with gimbals unplugged and both pots measure as expected.PhracturedBlue wrote: Have you tried it with the gimbals unplugged, or reversed? It would be useful to confirm the issue is on the board.
I'm using eight Sanyo Eneloop NiMH batteries and I have tried replacing with freshly charged batteries but with no change.PhracturedBlue wrote: Also, what are you using as a battery? The A/D circuitry is potentially very sensitive to the stability of the reference volatge.
12 Jun 2013 03:06 #10816
I don't have any great ideas for you.
If you can take a video of the monitor screen and give me an idea of how much is it moving around, it may help. We added heavy filtering to the devo12 to reduce noise, but at some point it slows down the response and becomes not useful.
- Martian
12 Jun 2013 09:51 #10839
by Martian
On the -100 to 100 scale it would vary in upwards of 40 points. I don't think you could filter out a 20% variance and be left with anything usable. I've exhausted all I know to do and will be sending it back.
I've worked in electronics manufacturing for over 10 years. This is a dead simple mod and I know I didn't botch it. I really have no idea what happened. I've ordered a new Devo 10 that should be here on Friday. Perhaps at some point I'll try the mod again, it would be really nice to be able to fly my V929 with the Devo, but for now I think I'll just be happy with the stock remote.
12 Jun 2013 10:12 #10840
...then probably I can't tell you anything new, but have you inspected your soldering points for any flux residue for example. It once happened to me, that the flux I used was conductive, and that caused a lot of suprising behaviour.
Martian wrote: I've worked in electronics manufacturing for over 10 years. This is a dead simple mod and I know I didn't botch it.
- Martian
12 Jun 2013 21:12 #10876
by Martian
I cleaned both sides of the main board with isopropyl alcohol and a brush / swab and compressed air then inspected under magnification. It's probably the cleanest Devo board in history.
as much as I hate to admit it I've given up on this one.
- w12martin
22 Jun 2013 14:03 #11236
by w12martin
Replied by w12martin on topic Left gimbal (THR / RUDD) erratic output
Hi there.
I had exactly the same problem with the throttle on my Devo 12S.
My Devo 12S is brand new and I was planing to use it on a 700e DFC.
After this issue came out I got really worried on using this transmitter in a 700e which could generates a serious accident.
Anyway I found the problem... The cable (sginal cable) that connects the potentiometer to the Throttle pin on the MB was too loose. In fact the three cables fit pretty loose and seem to be of a poor quality... After I tightened the pins with a pliers, the issue desapeared...
Hope this can help.
Hope this can help.
- BirdBarber
- Hummingbird Assassin
27 Jul 2015 14:39 - 27 Jul 2015 14:42 #36147
by BirdBarber
Replied by BirdBarber on topic Left gimbal (THR / RUDD) erratic output
Bumping an old thread here.
I had the similar problem with a Devo 10 elevator gimbal. About half the time when I centered it it would drift to -30 over about 5 seconds. I took the potentiometer out and cleaned it with Deoxit D5 and the problem went away.
To clean it I pointed the back side up and put a pool of Deoxit on top of it and worked the shaft for a couple of minutes. Then sprayed around the shaft on the front side and worked it for a couple of minutes. I re-installed it and it was a steady -4 when centered, so I re-calibrated the gimbals and it works great now. I got the Deoxit from Radio Shack.
The potentiometer looks just like these: www.aliexpress.com/item/SA-Japanese-NOBL...10MM/1302569488.html
These are 5K, mine measured 4.5K.
Last edit: 27 Jul 2015 14:42 by BirdBarber.
27 Jul 2015 15:09 #36151
R.I.P. In retrospect, trying to turn into a big box electronics store at a time when big box electronics stores were dying out was not a smart move.
So where do you get it now?
Replied by mwm on topic Left gimbal (THR / RUDD) erratic output
BirdBarber wrote: I got the Deoxit from Radio Shack.
- BirdBarber
27 Jul 2015 15:34 - 27 Jul 2015 15:35 #36158
by BirdBarber
They are in chapter 11 reorganization, not full on chapter 7 liquidation bankruptcy. They are only closing some of their stores. And it's still available on the Radio Shack web site. But I would hurry if I were you, lol. Amazon used to sell it also.
Last edit: 27 Jul 2015 15:35 by BirdBarber.
Time to create page: 0.197 seconds
- Left gimbal (THR / RUDD) erratic output
