Using Devo-10 and deviation for a RC CAR
- stein@office-center.no
09 Jul 2013 20:20 #12149
by stein@office-center.no
Using Devo-10 and deviation for a RC CAR was created by stein@office-center.no
HI
When buying som heliparts at my main supplier, Miracle Mart, I got a broken RC car for USD10. The ESC was broken. I thought it could be fun to see if i could make it work. Got a new ESC today and wanted to use the Devo-10 as I am more familiar with that kind of remote - I got to bind it - but only the steering worked. Any trick for making it work or is this a "no can do"?
Put back the original receiver and the engine worked fine by the way... There is no cable as for the helis for throttle.
The ESC is I bought was this one:
www.ebay.com/itm/261137606112?ssPageName...id=p3984.m1439.l2649
Anyone??
Stein
Anyone??
Stein
- Hot_Wheels
13 Jul 2013 04:12 #12224
by Hot_Wheels
Replied by Hot_Wheels on topic Using Devo-10 and deviation for a RC CAR
I would think it would work, can you plug a servo in the throttle port to see if your getting signal to the throttle channel? I bet the esc just needs to be programmed. If i recall to program disconect the motor and start the throttle to full power and back down, then the esc should beep?
14 Jul 2013 14:19 #12243
Replied by stein@office-center.no on topic Using Devo-10 and deviation for a RC CAR
HI.
I got it working. Dumbest fault of all. The ESC connector to the receiver was plugged to wrong connector. Case closed..
Stein
Stein
Time to create page: 0.212 seconds
- Using Devo-10 and deviation for a RC CAR
