Mix to Throttle
14 Jul 2013 13:52 #12242 by Nusmi
Mix to Throttle was created by Nusmi
hello ,
with the original firmware there is the option "mix to throttle" to maintain rotor speed when operatiing the Aileron, Elevator servo, and Rudder servo
is it possible to reproduce such a mix?
" Add XX% of THR when AIL ELE and RUD operate "
thank you
14 Jul 2013 19:47 #12245 by fabien
Replied by fabien on topic Mix to Throttle
Firstly welcome to the fantastic new world of custom firmware for radio, and now the serious things began :).
To do what you want you have to make a complex mix with 4 mixer on your throttle channel:
  • The first one is the throttle himself (a 1-to-1 curve while work perfectly)
  • The second and third is for aileron and elevator respectively in my example: it’s an ABSVAL curve with the scale set at XX% you want (20 in my example).
  • And for the last one for the rudder compensation you use a 1-to-1 curve agan with the scale at XX%. You may be have to change the type of curve for the rudder compensation because I’m not sure for this one.
I join to my post a picture of the throttle mixer
15 Jul 2013 11:18 - 15 Jul 2013 11:19 #12249 by Nusmi
Replied by Nusmi on topic Mix to Throttle
Merci pour ta réponse !
tu peu refaire ça en français ? :lol: j'ai un peu de mal a traduire :silly:
Last edit: 15 Jul 2013 11:19 by Nusmi.
15 Jul 2013 11:37 - 15 Jul 2013 11:38 #12250 by Nusmi
Merci en fait c'est bon ça fonctione avec ton image !
juste j'ai modifier en " ABSVAL " pour le Rudder aussi
j'ai aussi changer pour 5 au lieu de 20 sur les 3 chaines AIL/ELE/RUD
Merci a toi amis patriote ;)
Thanks , finally that's good ! with your picture!
I just modify "ABSVAL" for Rudder also and 5 instead of 20 for the 3 chanels AIL/ELE/RUD
Thank you very much :)
Last edit: 15 Jul 2013 11:38 by Nusmi.
Time to create page: 0.146 seconds
