Mix to Throttle
- Nusmi
14 Jul 2013 13:52 #12242
by Nusmi
Mix to Throttle was created by Nusmi
hello ,
with the original firmware there is the option "mix to throttle" to maintain rotor speed when operatiing the Aileron, Elevator servo, and Rudder servo
is it possible to reproduce such a mix?
" Add XX% of THR when AIL ELE and RUD operate "
thank you
thank you
- fabien
14 Jul 2013 19:47 #12245
by fabien
Replied by fabien on topic Mix to Throttle
Firstly welcome to the fantastic new world of custom firmware for radio, and now the serious things began
To do what you want you have to make a complex mix with 4 mixer on your throttle channel:
- The first one is the throttle himself (a 1-to-1 curve while work perfectly)
- The second and third is for aileron and elevator respectively in my example: it’s an ABSVAL curve with the scale set at XX% you want (20 in my example).
- And for the last one for the rudder compensation you use a 1-to-1 curve agan with the scale at XX%. You may be have to change the type of curve for the rudder compensation because I’m not sure for this one.
- Nusmi
15 Jul 2013 11:18 - 15 Jul 2013 11:19 #12249
by Nusmi
Replied by Nusmi on topic Mix to Throttle
Merci pour ta réponse !
tu peu refaire ça en français ?
j'ai un peu de mal a traduire
Last edit: 15 Jul 2013 11:19 by Nusmi.
- Nusmi
15 Jul 2013 11:37 - 15 Jul 2013 11:38 #12250
by Nusmi
Merci en fait c'est bon ça fonctione avec ton image !
juste j'ai modifier en " ABSVAL " pour le Rudder aussi
j'ai aussi changer pour 5 au lieu de 20 sur les 3 chaines AIL/ELE/RUD
Merci a toi amis patriote
Thanks , finally that's good ! with your picture!
I just modify "ABSVAL" for Rudder also and 5 instead of 20 for the 3 chanels AIL/ELE/RUD
Thank you very much
Thank you very much
Last edit: 15 Jul 2013 11:38 by Nusmi.
Time to create page: 0.282 seconds
- Mix to Throttle
