New Devo 12S and first problem
04 Aug 2013 15:27 #12753 by jelimi
New Devo 12S and first problem was created by jelimi
since a few days i have my new Devo 12S. It works great with my Master CP, V450-D03 und Super CP.
But now i want to create a airplane with flaperon. But this does not work. If i choose it, in the servo monitor i can see R-Aileron and L-Aileron, but they are standing at the side not in the zero position. I am looking in every menue, but i found nothing to change this.
I am from germany, hope to understand what i mean.
Regards
04 Aug 2013 16:26 #12754 by sbstnp
Replied by sbstnp on topic New Devo 12S and first problem
Question is are you running Deviation?
I can't help you with stock firmware and this is the case with most users here.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
04 Aug 2013 20:07 - 04 Aug 2013 20:07 #12758 by jelimi
Replied by jelimi on topic New Devo 12S and first problem
Thanks. Now i have tried to install the deviation Software, but it will not work. First i have install the 3.0 dfu file and then i have format the drive. After that i have copied the files from the deviation-fs-devo12-v3.0.0.zip to the drive, but then there is always only a blue screen on the 12S nothing else.
Can someone tell me what is wrong.
Thanks.
Last edit: 04 Aug 2013 20:07 by jelimi. Reason: Error
04 Aug 2013 20:43 - 05 Aug 2013 15:34 #12759 by RandMental
Replied by RandMental on topic New Devo 12S and first problem
You have to install also the .Lib file.
Edit: yes, my apologies for being so brief witrh the wromg file name, I meant the devo12-lib.dfu as Vlad said below
Last edit: 05 Aug 2013 15:34 by RandMental.
05 Aug 2013 06:02 #12767 by jelimi
Do you mean the file devo12-lib.dfu?
There i always get an error message from theDfuSe,
"Unable to find data for that device from the file"
05 Aug 2013 07:22 #12771 by vlad_vy
Replied by vlad_vy on topic New Devo 12S and first problem
You have to do this at 'Library' tab of Dfuse.
Time to create page: 0.598 seconds
