Devo 8S + Phoenix = Not working correctly
- PatrickN
08 Aug 2013 07:47 #12835
by PatrickN
Devo 8S + Phoenix = Not working correctly was created by PatrickN
Hi there,
another totaly noobie have some questions to this nice transmitter.
So i get a Devo 8S and a little nice MiniCP a few Days ago. After some crashes i decided to train with a Sim first.
I got a USB Cable from a Friend to test if it works.
But it doesn't.
Phoenix recognize my Devo 8S, but with no Setting i tried so far i get a good Setup for flying a Helicopter.
Most of the Time the Chanels are mixed around.
On my Transmitter i put Gas, Pitch, etc. on Channel 1-4 and turn every mixing function off.
Phoenix show my Channel 1 is Pitch, Channel 6 is Gas, and so on. Some channels dont even work.
Do i something terribly wrong, or should i get a new USB-Interface, or is the Deviation Software not working propperly with Phoenix?
Greeting from Germany
(Sorry for my poor english!)
Patrick
But it doesn't.
Patrick
08 Aug 2013 09:16 - 08 Aug 2013 09:20 #12838
Replied by rbe2012 on topic Devo 8S + Phoenix = Not working correctly
Welcome Patrick,
it seems you have installed deviation - or are you running the stock firmware?
Phoenix is a simulator often used and I have read some threads where it works good.
Take a look at these threads:
devo10 on phoenix
support for phoenix
8s with phoenix
devo10 on phoenix
support for phoenix
8s with phoenix
Last edit: 08 Aug 2013 09:20 by rbe2012. Reason: invisible links
- PatrickN
08 Aug 2013 09:34 #12840
by PatrickN
Replied by PatrickN on topic Devo 8S + Phoenix = Not working correctly
Yeah, im running Deviation firmware.
i tried some of the configs yesterday, but nothing really works for me.
also it seems that every time i start phoenix my channels are back to where i startet, even when i save it as a new transmitter.
i try to make a more detailed post today when i am at home.
Do i miss some settings to do before i connect my trasmitter via PPM?
- RandMental
08 Aug 2013 21:48 #12847
by RandMental
Replied by RandMental on topic Devo 8S + Phoenix = Not working correctly
Patrick, are you using the Phoenix supplied PPM to USB dongle or the USB HID interface (eg a normal USB cable)?
- PatrickN
12 Aug 2013 15:02 #12928
by PatrickN
Im using a PPM cable i get from a friend.
Seems that my Setting were crap.
I installed the firmware, i resetted all settings and calibrated the TX in Phoenix and now im fine.
Dont do anything other as the first time, but now it works.
thanks for your help and time. =)
Time to create page: 0.069 seconds
- Devo 8S + Phoenix = Not working correctly
