Hardware query: Switch types & availability?
- Damo
10 Aug 2013 07:42 #12884
by Damo
Hardware query: Switch types & availability? was created by Damo
I managed to drop my devo 10 about 5 minutes ago, and it would appear the Rudder D/R switch top left took the brunt of the fall - after the incident it switched once, binding, and no longer switches. It (the actual lever) also is able to be pressed further into the case than the others.
Has anyone replaced one of these switches, and knows a supplier and part number of a compatible switch?
Thanks in advance,
Damo.
ps. I will be dismantling the unit to see if the switch is repairable, but I doubt it.
Thanks in advance,
Damo.
- Daryoon
10 Aug 2013 19:49 - 10 Aug 2013 19:49 #12894
by Daryoon
Replied by Daryoon on topic Hardware query: Switch types & availability?
I don't have a Devo 10. But you can check HobbyKing for the
switches used on the 9XR radio
. I think they will be compatible.
Last edit: 10 Aug 2013 19:49 by Daryoon.
- Damo
10 Aug 2013 22:44 #12896
by Damo
Replied by Damo on topic Hardware query: Switch types & availability?
Thank you Daryoon, I think they will work ok.
Looking at the image, I may be lucky, the plastic switch block may have popped away from the metal top plate. I had better pull it apart and have a look.
Thanks again.
Thanks again.
- Damo
10 Aug 2013 23:24 #12897
by Damo
It was two issues - the switch block and plate/lever assembly had separated, and the impact had bent the switching plate inside the switch itself. Straightened the plate, reassembled the switch and its working 100%.
- jason4207
14 Aug 2013 22:51 #12982
by jason4207
Replied by jason4207 on topic Hardware query: Switch types & availability?
Good work!
I got extra switches for my Devo 7E at Radio Shack for future reference.
- adabman
29 Aug 2013 23:21 #13381
by adabman
Deviation
1 TX to rule them all...
Replied by adabman on topic Hardware query: Switch types & availability?
Just a FYI.. I broke my gear switch on Devo 12S. These looked like a good match so I ordered a few:
www.ebay.com/itm/2PCS-SPDT-Flat-Shaft-Me...&hash=item43adfa930e
However, the threads were the wrong pitch, so the Devo nut would not wind on. Too bad, took weeks for shipping.
Deviation
Time to create page: 0.126 seconds
- Hardware query: Switch types & availability?
