Ladybird V1 Can not bind after firmware upgrade
- SilbernerSurfer
15 Aug 2013 16:30 #12995
by SilbernerSurfer
Ladybird V1 Can not bind after firmware upgrade was created by SilbernerSurfer
i can not bind my Ladybird V1 with my Devo 7e after upgrading to 3.0.0!
I have tried Auto-bind and fixed id binding.
Any ideas?
Any ideas?
15 Aug 2013 16:33 #12996
Replied by vlad_vy on topic Ladybird V1 Can not bind after firmware upgrade
Do you reset Fixed Id at Ladybird with bind plug?
- SilbernerSurfer
15 Aug 2013 16:51 - 15 Aug 2013 16:52 #12997
by SilbernerSurfer
Replied by SilbernerSurfer on topic Ladybird V1 Can not bind after firmware upgrade
Yes, i put the bind plug in. After connecting with the batterie quick blinking turns into slow blinking.
Than i switched on the Devo 7e Choose "Devo" and press the Bind-button.
Than removed the bind plug and it blinks quick. That is all. no binding.
Last edit: 15 Aug 2013 16:52 by SilbernerSurfer.
- sbstnp
15 Aug 2013 17:04 - 15 Aug 2013 17:04 #12998
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Ladybird V1 Can not bind after firmware upgrade
Make sure you power up once with the bind plug inserted, then pull it out and re-power.
The bind plug is not a real bind plug, it's more like a clear ID plug. Don't try to bind with it inserted.
Devo 10 + 4in1
Last edit: 15 Aug 2013 17:04 by sbstnp.
- SilbernerSurfer
15 Aug 2013 17:50 - 15 Aug 2013 17:51 #12999
by SilbernerSurfer
I have tried this, but does not work.
Maybe my FCB is faulty. I had a crash before upgrading to 3.0.0!
With the original software i could bind. Only the left back motor doesnt run. When iam pressing the FCB a little bit the motor runs. I think this is a wacky contact resulting from a chrash.
The Ladybird was able to bind with the original software and the wacky contact.
But now the FCB doesnt bind with the 3.0.0.
Only fast blinking without the bind plug.
Maybe i have to wait for my new FCB from Banggood. It should arrive at 1 or 2 weeks.
Last edit: 15 Aug 2013 17:51 by SilbernerSurfer.
- Drexz
15 Aug 2013 19:12 #13000
by Drexz
Replied by Drexz on topic Ladybird V1 Can not bind after firmware upgrade
Try to bind with the tx a few meters away from the rx.
Had the same issue with a mCPX v2 and didnt work before we tried with the tx on the other side of the room.
I think it has to do with interference, but not sure.
- SilbernerSurfer
15 Aug 2013 19:44 - 15 Aug 2013 19:44 #13001
by SilbernerSurfer
I have tried it, no success!
Last edit: 15 Aug 2013 19:44 by SilbernerSurfer.
- SilbernerSurfer
15 Aug 2013 23:30 #13002
by SilbernerSurfer
I get it now. the spin box was set on bind. i have setted it on re-init and it works. but the LED flashes green now. how can i get it to flash red?
16 Aug 2013 03:53 #13003
Check your 7ch, if value < +32% = 6 axis mode(red LED), if value >+32% = 3 axis mode(green LED).
Time to create page: 0.049 seconds
- Ladybird V1 Can not bind after firmware upgrade
