Swash mix question.
- Damo
09 Sep 2013 16:14 #13665
by Damo
Swash mix question. was created by Damo
I am using the model from this thread: www.deviationtx.com/forum/model-configs/...ybar-with-2801#13664
with my 450 Sport clone, I have changed the channel assignments to work with the DSM2 AR6100e Rx I have.
Pitch works fine - swash moving up and down nicely with all servos moving in correct direction.
Elevator works, rear servo moving with front servos moving a bit in opposite direction, tilting swash in correct direction.
Aileron is reversed, cyclic left is tilting swashplate to the right.
Using advanced mixer view, in CYC-AIL I am changing the Src to !AIL, but It is not reversing the swash tilt.
What am I doing wrong?
09 Sep 2013 16:35 #13666
Replied by FDR on topic Swash mix question.
You should reverse it on the swash options.
- domcars0
09 Sep 2013 16:37 #13667
by domcars0
Replied by domcars0 on topic Swash mix question.
Go to the Model Setup, Click on the <Heli> Model type, then change the AIL Inv to 'Inverted'.
Hope this help.
Hope this help.
- Damo
09 Sep 2013 17:00 #13668
by Damo
Replied by Damo on topic Swash mix question.
Thanks guys, fixed. This is one helpful forum!
Time to create page: 0.068 seconds
- Swash mix question.
