HOW TO SET FAILSAFE ON DEVO 10
- AKA_TEKK
14 Sep 2013 13:30 - 14 Sep 2013 13:35 #13783
by AKA_TEKK
HOW TO SET FAILSAFE ON DEVO 10 was created by AKA_TEKK
I'm a newbie with the DEVO 10. Could somebody tell me how to set the FAILSAFE. I set failsafe for all channels, for the test I took off the blades, gave a bit of throttle to get he motors spin, and then turn off my Devo10, the quad doesn't power down, actually the motors even turn stronger. Could someboy look into my file.
i'm using a KK2 board with RX 1002
thanks
thanks
Last edit: 14 Sep 2013 13:35 by AKA_TEKK.
14 Sep 2013 16:12 #13785
Replied by FDR on topic HOW TO SET FAILSAFE ON DEVO 10
It looks right.
Does the throttle hold stop the motors? If it does, try to set the failsafe value to -100 as well...
- AKA_TEKK
14 Sep 2013 16:35 #13786
by AKA_TEKK
Replied by AKA_TEKK on topic HOW TO SET FAILSAFE ON DEVO 10
hello FDR,
the THROTTLE HOLD safety (RUD DR1) is working and it is already at -100. My FailSAFE for the throttle is -125, Ail/Ele/Rud are set to 0.
- kc8cyf
14 Sep 2013 16:40 #13787
by kc8cyf
Replied by kc8cyf on topic HOW TO SET FAILSAFE ON DEVO 10
Second that!
Set the throttle failsafe to -100 or L100... zero is mid-stick on the throttle.
I learned the hard way after a heli crash and turning off the Tx caused the motor to spool up! I had the fail safe at zero!
Heli did the chicken dance in the dirt... had the failsafe been set to -100 / L100 the damage would have been minimal. The running motor torn the heli apart.
Good Luck
Good Luck
14 Sep 2013 16:41 #13788
Yes, I saw, that's why I suggest to set the throttle failsafe value to -100 too.
May be your board misinterprets the smaller -125 value.
All the other failsafe values are useless in a quad if you kill the throttle...
- AKA_TEKK
14 Sep 2013 16:54 #13789
by AKA_TEKK
still spinning at -100 for the throttle failsafe, the number doesn't affect the speed of the motor, I tried to put different values, the motors seem to keep the same speed. weird
- sbstnp
14 Sep 2013 16:59 #13790
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic HOW TO SET FAILSAFE ON DEVO 10
Are your ESCs calibrated?
Devo 10 + 4in1
- AKA_TEKK
14 Sep 2013 17:09 #13791
by AKA_TEKK
yes they are.
- AKA_TEKK
14 Sep 2013 17:35 #13793
by AKA_TEKK
I will recalibrate them once more to see, Have to go now, will let u know.
- AKA_TEKK
14 Sep 2013 19:38 #13796
by AKA_TEKK
It works! After recalibrated the ESC ;0)
I was really LUCKY this morning, I took out the propellers before repairing a wire on the motor, did a quick test after soldering job done, TOO QUICK on the OFF TX's button even before turn OFF the KK2 board, BAM! The motors spin like crasy, wow that was close! The same time, I reallize the problem of the failsave...
- GxA
14 Nov 2015 18:19 - 14 Nov 2015 20:59 #40054
by GxA
Replied by GxA on topic HOW TO SET FAILSAFE ON DEVO 10
Hi, I have a problem I changed the receiver Walkera qr 350 pro at rx 1002, everything works, the connection restores, but fail safe does not work, how to set up with devo10, please help.
Last edit: 14 Nov 2015 20:59 by GxA.
Time to create page: 0.321 seconds
- HOW TO SET FAILSAFE ON DEVO 10
