devo 8s range test
20 Sep 2013 11:49 #13922 by harmony96
devo 8s range test was created by harmony96
I'm worried that my devo 8S is defective.
Would you let me know a normal range of devo 8s with orange receiver R615 in a case that TX power is set to 100uW.
I got only 10m in perfect line of sight condition.
If I put it in a foam plane, I got only 4~5m in the same condition.
Is it normal?
Spectrum TX suggests that TX should control a plane far from 30paces (maybe about 30m?) in range test mode, which is 1/1000 power from the normal TX power.
So, the TX power of spectrum TXs will be roughly 100uW in the range test mode.
It means that my devo 8s got only 1/6 range compared with the specturm TX, which is very short.
I'm worried that my devo 8S is a lemon.
20 Sep 2013 16:58 #13931 by billmester
Replied by billmester on topic devo 8s range test
you might want to set it to 100mW instead of 100 uW.
miliwatt is 1000 times more powerful than microwatt
20 Sep 2013 20:27 #13939 by dehalo
Replied by dehalo on topic devo 8s range test
I get ~10 m with a Devo7E @100µW with Devo (Ladybird), WK2801 (4G3) and DSM2 protocols.
10 m @100 µW should mean that you get ~300 m @100 mW, seems OK.
Time to create page: 1.013 seconds
