7e, Nightly Build, No reset possible.
- SilbernerSurfer
13 Oct 2013 10:28 #14552
by SilbernerSurfer
7e, Nightly Build, No reset possible. was created by SilbernerSurfer
I cant reset my models with the 7e and the Nightly build.
After enter the reset button my 7e switches off after 2 or 3 seconds.
I have to restart the 7e and the model isnt resetted.
Uwe
Uwe
13 Oct 2013 12:23 #14555
Replied by vlad_vy on topic 7e, Nightly Build, No reset possible.
Do you have at Tx filesystem 'template' folder and 5 .ini files inside?
- SilbernerSurfer
13 Oct 2013 19:41 #14574
by SilbernerSurfer
Replied by SilbernerSurfer on topic 7e, Nightly Build, No reset possible.
Yes
13 Oct 2013 19:50 #14577
Replied by rbe2012 on topic 7e, Nightly Build, No reset possible.
Model reset does not go back to a template. It needs a config called default.ini in the models-folder.
Please check this.
Please check this.
- SilbernerSurfer
13 Oct 2013 22:48 #14584
by SilbernerSurfer
Yes, here it is:
[radio]
protocol=DEVO
num_channels=8
fixed_id=123456
tx_power=10mW
[channel1]
template=simple
[mixer]
src=ELE
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Auto=min
[radio]
protocol=DEVO
num_channels=8
fixed_id=123456
tx_power=10mW
[channel1]
template=simple
[mixer]
src=ELE
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[safety]
Auto=min
14 Oct 2013 03:55 #14589
I think something wrong with Tx filesystem. Can you backup your model files, format Tx filesystem, rewrite filesystem from archive, restore your model files and recalibrate sticks?
Also, how charged Tx battery? It can be related to battery low voltage.
- SilbernerSurfer
14 Oct 2013 20:29 #14646
by SilbernerSurfer
I found it!
I have made a mistake by making a back up from the model file.
I copied a complete model folder into the model folder of the Tx.
So i had the model.ini's and a complete model folder in it.
I have deleted the model folder inside the model folder and the reset button is working now.
What a mistake!!!!
What a mistake!!!!
Time to create page: 0.514 seconds
- 7e, Nightly Build, No reset possible.
