Devo 8s convert switch to knob?
- shadow
26 Oct 2013 00:19 #14980
by shadow
Devo 8s convert switch to knob? was created by shadow
Ok can a switch be converted to a rotary knob on the devo 8s?
26 Oct 2013 06:46 - 26 Oct 2013 06:47 #14984
Replied by rbe2012 on topic Devo 8s convert switch to knob?
A rotary know will need at least two inputs and the order of signals tell you which direction the knob is turned (if you're talking about a digital one). So you could replace one 3-way-switch or two 2-way-switches by such an encoder.
If you want an analog knob (like the knobs and sliders on Devo10 and 12) you need an analog input to connect it. There are some, but mostly used or you would have to solder a wire at a very small pin directly at the processor (and care for a clean signal) (GPIO A0, C5).
Last edit: 26 Oct 2013 06:47 by rbe2012.
- shadow
26 Oct 2013 12:08 #14994
by shadow
Replied by shadow on topic Devo 8s convert switch to knob?
Ok thanks I may do that one day. But think I will stick with the switches for now.
Time to create page: 0.298 seconds
- Devo 8s convert switch to knob?
