Please advice - is this range issue? Crashed Quad
27 Oct 2013 23:14 - 27 Oct 2013 23:17 #15062 by s4ntai
Hello Everyone,
First time on the forum, Could you please advice if this is a range issue?
Please see video
I'm flying my quad in my RC club field, probably about 30 meter away from me, and suddenly lost control of the craft (once it's lose it's balance and it goes full throttle itself), not responding to any throttle or any stick movement.
I have flown further than this last week and I don't have any issues.
Battery have 3 bar strip on it
Transmitter - Devo 7e
Receiver - RX601
People in the club think its because I pointed my antenna straight to the quad, which is my bad habbit
I can do the soldering by pass on the transmitter but
I'm not really a wiz with computer, is there a link where it guide me step by step to upgrade the firmware?
Thank you so much
Last edit: 27 Oct 2013 23:17 by s4ntai.
28 Oct 2013 03:40 #15064 by vlad_vy
Firmware version?
28 Oct 2013 10:09 #15070 by s4ntai
Stock Walkera, I haven't update or mod anything. out of the box with no mod yet.
28 Oct 2013 10:32 #15072 by FDR
It has about 7mW power then, so antenna direction and rx placement are indeed important factors...
28 Oct 2013 12:46 #15075 by s4ntai
Just done range mod and Deviation firmware update on Devo 7e.
now it's not binding with my super cp or RX601,
is that mean my transmitter is a gonner?
28 Oct 2013 12:55 #15076 by FDR
Did they worked with deviation before the mod, or did you change both at once?
Don't forget to clear the fixed id value on the model setup page to allow auto binding with the DEVO protocol.
Also don't forget to enable the power amp in the tx.ini file...
28 Oct 2013 19:58 - 28 Oct 2013 19:59 #15092 by s4ntai
Hello FDR.
Sorry, I didnt test the firmware before i did the range mod.
All good.
I manage to bind it. I clear the fixed id number and it worked with rx-601.
My next question. I set the power to 150mW. Is there away to check if my range mod successful. Without sacrificing the bird?
Or i just need to put the bird on the far end of the field and test to see if this will bind?
Last edit: 28 Oct 2013 19:59 by s4ntai.
28 Oct 2013 20:19 #15094 by FDR
Use some reduced power setting, say 1mW.
Set a fail safe value on a channel to see when it looses link.
Put the tx on a chair or ground and walk away with the model until it looses the link.
Calculate the range for larger power...
28 Oct 2013 21:15 #15095 by s4ntai
FDR,
Thank you for the advice.
I'll try it when I got home.
say. 1mW got me 3 meter, so is that mean. is I set it to 150mW x 3 Meter? that equates 450 meter?
Thank you
28 Oct 2013 21:34 #15096 by FDR
29 Oct 2013 00:17 #15102 by s4ntai
Thank you FDR
Time to create page: 0.194 seconds
