Color text
31 Oct 2013 11:44 #15167 by Franck
Color text was created by Franck
Je voudrais changer la couleur du texte sur l'écran. Je veux m'être un fond noir et avoir une police blanche. Est-ce possible ? merci
I want to change the color of text on the screen. I want myself a black background and have a white font. Is this possible? thank you
31 Oct 2013 11:58 #15168 by FDR
Replied by FDR on topic Color text
Last time I tried to do that it wan't possible, because I couldn't change all the colors, but that was long time ago...
01 Nov 2013 13:22 #15193 by Franck
Replied by Franck on topic Color text
J'ai réussi à faire quelque chose de plutôt jolie ! Il me reste deux pages ou je n'arrive pas à mettre le texte en blanc. Si quelqu'un a une idée pour m'aider ! Merci
I managed to do something rather nice! I have two pages and I do not put the text in white. If someone has an idea to help me ! thank you
  • rbe2012
  • rbe2012's Avatar
01 Nov 2013 14:10 #15194 by rbe2012
Replied by rbe2012 on topic Color text
In media/config.ini set the font color:
[font-tiny]
;Channel display
  font=5x7
  font_color=ffffff
;  font=arial10narrow
  box_type=center
(ffffff=RGB(0xff,0xff,0xff)=white)
01 Nov 2013 14:35 - 01 Nov 2013 14:41 #15195 by Franck
NICE !!!
Thank you so mutch rbe2012 .....
Last edit: 01 Nov 2013 14:41 by Franck.
01 Nov 2013 16:35 #15199 by Franck
Une autre couleur à modifier / Another color change
[trim]
fg_color_pos = FDFD00
fg_color_neg = FDFD00
outline_color=FFFFFF
transparent=1
Quand les trims sont au neutre il sont noir, je voudrais modifier la couleur. La couleur que j'ai reussi a modifié est quand le trim n'est pas au neutre / When the trims are in neutral they are black, I would like to change the color. The color that I got changed is when the trim is not neutral
  • rbe2012
  • rbe2012's Avatar
01 Nov 2013 17:17 #15203 by rbe2012
Yes, the color of the neutral point is defined in the media/config.ini in the [trim]-section:
[trim]
  bg_color=800080
  fg_color=FFFF00
  fg_color_pos=FF0000
  fg_color_neg=0000FF
  fg_color_zero=00FF00
  outline_color=FF40FF
  transparent=1
bg_color for the background if transparent=0,
fg_color for all (if no special colors given),
.._pos for positive trim values,
.._neg for negative,
.._zero for the neutral point,
outline_color for the frame.
01 Nov 2013 17:45 #15206 by Franck
you're the best, thank you again
what do you think of my screen ?
01 Nov 2013 20:04 #15208 by Franck
Tu as l'air plutôt bon en programmation pour le logiciel déviation, je te pose une autre question ! Est-il possible d'afficher une image à l'allumage de la radio avec une temporisation ?
You look pretty good programming software for the deviation, I ask you another question! Is it possible to display an image to the lighting of the radio with a timer?
02 Nov 2013 07:06 #15216 by Franck
I found the right word, is the splash screen I'm looking for!
  • rbe2012
  • rbe2012's Avatar
02 Nov 2013 09:28 #15222 by rbe2012
media/splash.bmp
02 Nov 2013 11:54 #15231 by vlad_vy
Replied by vlad_vy on topic Color text
With nightly builds only.
02 Nov 2013 15:16 #15246 by Franck
vlad_vy wrote: With nightly builds only.
I tested the version builds, but the toggle bar is different and has to change too ... damage.
04 Nov 2013 07:11 #15316 by Franck
ok, I installed the build version introduced the toggle switches. How does one increase the tempo of the splash screen?
04 Nov 2013 07:14 #15317 by Franck
Ok ! it's splash_delay in TX.ini
Time to create page: 0.588 seconds
