Binding issue with Devo rx's on my 8s w/4.0
06 Jan 2014 05:51 #18043 by Keith5031
:blush: Hey guys, I can't seem to get any of my devo rxs to bind with my 8s. I did get Flysky, DSM2 and a Tactic SLT, but no luck with the devo rxs, 6 or 8 channel ones. I must be doing something wrong.
06 Jan 2014 06:10 #18044 by vlad_vy
Replied by vlad_vy on topic Binding issue with Devo rx's on my 8s w/4.0
Probably you need clear 'Fixed ID' in your Tx. Also, probably you need reset 'Fixed ID' in your Rx.
06 Jan 2014 17:02 #18087 by Keith5031
Replied by Keith5031 on topic Binding issue with Devo rx's on my 8s w/4.0
I tried clearing the rx and not using the fixed id. I don't understand. I tried Devo, 2801, 2601 and 2401 with no luck. I even tried to use the bind plug with no luck. I don't believe there is anything to do with the FW.
  • rbe2012
  • rbe2012's Avatar
06 Jan 2014 19:04 #18090 by rbe2012
Replied by rbe2012 on topic Binding issue with Devo rx's on my 8s w/4.0
Take a look in your tx.ini - there was a build where the config lines for the modules were damaged. Correct is:
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105    = None
has_pa-a7105    = 0
enable-cc2500   = None
has_pa-cc2500   = 0
enable-nrf24l01 = None
has_pa-nrf24l01 = 0
(with the additional protocols enable by replacing "None" with the corresponding output line)
07 Jan 2014 05:58 #18129 by vlad_vy
I think it's not a case, as he can bind with DSM2 and Flysky.
07 Jan 2014 15:30 #18143 by Keith5031
As vlad_vy said, I don't think it's a problem with the code. I don't know how to do a bug, I tried last night and all I was able to do is make an account of my own. I couldn't post on PhractuedBlue's bitbucket. I have plenty of Flysky,DSM2 rs's, but I bought almost a dozen Devo rx's and it stinks I can't use the original protocol rxs. If anyone has any advise, I'm all ears. Thanks.
  • rbe2012
  • rbe2012's Avatar
07 Jan 2014 16:12 #18147 by rbe2012
Have you tried to reinstall 4.0 (or 4.0.1)?
Did you start with a new model?
Could you post your tx.ini and modelXX.ini and let us have a look?
07 Jan 2014 21:20 #18160 by Keith5031
Hey guys, I reinstalled 4.0 and also 4.0.1 with no luck in getting any of my Devo rxs to bind. I did bind somemore Flysky and DSM2 rxs and it went fine. I also was able to put in a bug issue, hope I did it right. Right now :) it's not a big deal, weather not cooperating and all. I appreciate everyone's effort in trying to get this figured out for me, I don't know if anyone else has had this problem or not and if they found a solution that worked.
07 Jan 2014 22:50 #18163 by HappyHarry
Replied by HappyHarry on topic Binding issue with Devo rx's on my 8s w/4.0
perhaps you should double check your added module installs, as the issue is most likely there
08 Jan 2014 04:40 #18186 by Keith5031
:woohoo: Hey everyone, SUCCESS! I opened up the Tx and re-checked everything like HappyHarry suggested. I found a spot between pins 3 and 4 on the Devo chip where I soldered. It looked like I may have joined those two at the base with just alittle solder. I scraped until I could see no more solder. Tried it again and got an 8 channel and 6 channel rx to bid right off with clearing the rx and the id and to the Devo protocol, not any below that. I will try the others, but am happy that I got it to work thanks to you guys and your suggestions. I really do appreciate it. :cheer: Thanks Everyone. B)
  • rbe2012
  • rbe2012's Avatar
08 Jan 2014 06:30 #18194 by rbe2012
Good to hear. Now you can have fun with Deviation again...
08 Jan 2014 16:27 #18225 by Keith5031
Yes I can, as I said before, I appreciate everyone's generosity here. I have always been told that most problems are solved by something simple. But we always make it a bigger problem than it is, just like this. I would never have thought to take another look at the wiring/soldering I did. Thanks again everyone, time for lots more fun.
08 Jan 2014 16:55 #18226 by HappyHarry
just for future reference please include all pertinent info in your forum posts, if i'd not read your bitbucket issue i wouldn't have known you'd done any module additions, and i wouldn't have thought to suggest looking there for the problem :)
08 Jan 2014 18:26 #18234 by FDR
It was obvious, since he wrote that FlySky and Tactic SLT worked...
08 Jan 2014 20:49 - 08 Jan 2014 20:50 #18246 by HappyHarry
yeah but what wasn't obvious is that the problems started right after he added the modules, and that he had just done said module additions.....
Last edit: 08 Jan 2014 20:50 by HappyHarry.
08 Jan 2014 21:59 #18249 by Keith5031
:P Guys, it's not a question weather or not I posted enough info or what I posted implied I had done any mods or not. It is the fact I had a problem and all of you helped me figure it out and fix it. Many thanks to all of you. B)
Time to create page: 0.675 seconds
