Devo 6 idetical config from?
07 Jan 2014 09:53 #18136 by ttermi
Devo 6 idetical config from? was created by ttermi
i am new in this forum. I am have a v120D02s with the original Radio ( i do not know the Name now! - i am in a office).
I have buied in 2012 a Devo6 Radio. I have also a Align T-Rex 450.
I tried so often to config the Devo 6. but it is not working. Today i find this Site!
So my first question.
With wich Radio is the Devo6 identical with Devo 8 (difference are the Channels)?
Which configuration file can i use for the V120d02s and Devo6?
PS: Sorry for my bad English. I am German....
  • rbe2012
  • rbe2012's Avatar
07 Jan 2014 10:56 #18138 by rbe2012
Replied by rbe2012 on topic Devo 6 idetical config from?
Welcome.
First you should be sure that you want to install deviation on your Devo6. If so, we can assist you with getting a working config (I am sure if you search you will find some since the V120-helis are well used).
The Devo6 is more or less like a Devo8 besides some missing switches (and the upper trims). You should be able to use a Devo8-V120-config with little changes concerning the switches.
07 Jan 2014 11:33 #18140 by ttermi
Replied by ttermi on topic Devo 6 idetical config from?
That sound good!
Is it possible to switch bewteeen the original Firmeware and the Deviation Firmeware? Or is it only one way - means, if i switch to Deviation i can not go back to the original Firmeware?
I see some config Files for the v120 in combination Devo8.
07 Jan 2014 12:42 #18141 by vlad_vy
Replied by vlad_vy on topic Devo 6 idetical config from?
You can do it as many times as you want.
Time to create page: 0.187 seconds
