4.0.1 - Devo 7e - Blade NanoCPX Problem
10 Jan 2014 21:45 #18331 by Alexander
4.0.1 - Devo 7e - Blade NanoCPX Problem was created by Alexander
Hi all,
I have a problem with 4.0.1 and Devo 7E with the Blade Nano CPX.
All servos are working correctly according to the stick movements, but when I throttle up, the swashplate starts moving slowly to the right/forward, so the heli is not controllable.
To verify that the heli is ok, I bound it to my Spektrum DX8 radio --> heli flies totally fine.
Can someone help me with the problem? When using the Mini CP with the 7e everything is fine.
Thanks and regards,
Alexander
PS: See my NanoCPX 7e ini-file attachted.
10 Jan 2014 21:50 #18332 by FDR
Replied by FDR on topic 4.0.1 - Devo 7e - Blade NanoCPX Problem
I don't see any gyro sensitivity settings in your config. Doesn't it needed?
Also the rudder channel (ch4) has unneeded mixers as it was an expo&dr template while it is just a simple one...
10 Jan 2014 22:20 #18333 by Alexander
Replied by Alexander on topic 4.0.1 - Devo 7e - Blade NanoCPX Problem
Hi FDR,
thanks for the quick reply. The Nano CPX does not need gyro set.
I tried several configs, but every config had the problem I described.
Could it be the general Helicopter template? It says:
Swashtype: None --> is this ok?
ELE,AIL, COL Inv: Normal
ELE,AIL, COL Mix: 60 --> What does 60 mean?
Even after changing the Mix values to 0 and the swashtype to 90 the problem is still there. Changing from DSMX to DSM2 also did not help :-(
Kind regards,
Alexander
10 Jan 2014 22:42 #18334 by Tom Z
Replied by Tom Z on topic 4.0.1 - Devo 7e - Blade NanoCPX Problem
Hi Alexander, as a test try my Blade 130 X - Standard Settings model. The settings are the same as the NanoCPX except the throttle curve for normal modes. Let me know if this model works for you. If it does I know there is something not correct with the NanoCPX model and will try to figure it out.
These are Walkera firmware values. I converted them for the deviation values.
when I made the models.
NanoCPX - Normal throttle curve - 0% 40% 60% 80% 100%
Blade 130 X - Normal throttle curve - 0% 40% 60% 68% 75%
www.deviationtx.com/forum/model-configs/...-x-standard-settings
10 Jan 2014 22:54 - 10 Jan 2014 23:02 #18335 by Tom Z
Swashtype: None is what you want for FBL.
I think None = 1 SERVO NORM
Posted by: Hexperience
"There is a setting in the Helicopter config page for swash type. NONE is the default which obviously means no ccpm mixing".
Last edit: 10 Jan 2014 23:02 by Tom Z.
10 Jan 2014 23:03 - 10 Jan 2014 23:04 #18336 by Alexander
Hi Tom,
thanks, I tried your 130X config. But the problem with the swashplate is still there. As I throttle up, the left servo moves slowly up and the right servo moves slowly down. When throttle is off, the servos return to the correct positions immediately.
I also have a Devo 8s with 4.0.1 which has no problem with the Nano CPX...
PS: All tests where done with the SwashType set back to "none".
Regards,
Alexander
Last edit: 10 Jan 2014 23:04 by Alexander.
10 Jan 2014 23:14 #18337 by Tom Z
Your welcome.
So the model works in your Devo 8s with v4.0.1 but it doesn't work with your Devo 7e?
Someone flew the model with their Devo 7e v4 and it worked fine.
10 Jan 2014 23:31 #18338 by Tom Z
Here is a model I made in the Devo 10 V4 emulator for the NanoCPX - Standard Settings. It should work in the 7e also if you want to try it.
It is not posted on the site as I made an all in one model instead.
File Attachment:
File Name: model76.ini
File Size:2 KB
10 Jan 2014 23:31 #18339 by Alexander
Yes, with my Devo 8s v.4.0.1 the Nano CPX works fine. Then I took the Devo 8s Nano CPX config and copied it to my Devo 7e with the described problem. After that I tried some other configs from the forum including yours with the same result :-(
You know what I did.. I took your 130X config and tried it with the Devo7e and my 130X (I have a lot of helis). Guess what... the exact same problem as with the Nano CPX! Very strange.
10 Jan 2014 23:36 #18340 by Alexander
Hi Tom,
thanks for your effort. I tried the model76.ini with the same problem :-(
Well, I think I will flash my Devo 7e again tomorrow.. maybe the problem will go away. I'll let you know.
Regards,
Alexander
10 Jan 2014 23:43 - 10 Jan 2014 23:45 #18341 by Tom Z
Your welcome.
That was a good idea that you tried some models made by other people. That tells us the problem shouldn't be in the model ini file unless it isn't importing correctly in the 7e. But someone already tried my model in their 7e V4 and it worked fine.
Let's see what FDR and/or the tech guys say when they read your post here as I have no clue what the problem can be. Very strange for sure.
Last edit: 10 Jan 2014 23:45 by Tom Z.
11 Jan 2014 00:08 #18344 by Tom Z
FDR wrote: Also the rudder channel (ch4) has unneeded mixers as it was an expo&dr template while it is just a simple one...
I made a master model for the Blade helicopters which all I have to do is change pitch curves, throttle curves, and DR/Expo for most models.
Some of them I use DR/Expo on the rudder and others I don't.
  • rbe2012
  • rbe2012's Avatar
11 Jan 2014 08:15 - 11 Jan 2014 08:26 #18353 by rbe2012
Replied by rbe2012 on topic 4.0.1 - Devo 7e - Blade NanoCPX Problem
Alexander,
you can try my config. I just have flown my Nano with this (for the first time with Devo7e) and it works - is surely not perfect and you have to adapt it to your needs.
But I have not seen any servo creeping with this config.
I would expect that you have an issue with the AS3X stabilizer. If it recognizes a movement of the heli it will try to correct this. So maybe for some reason the unit has wrong inputs or reactions. Can also be a result of improper initialization. Plug the battery in and place the heli on a stable flat surface until binding is complete and the blue light is solid.
The other issue I could imagine is a defective servo. If you dismount it you can screw the motor unit off the board. There are two lines where a slider is moved up and down on the board. Maybe you should clean them (with gasoline used for cleaning purposes). But mostly the servo jitters only if there is some dirt inside.
EDIT: attached the correct config file now.
Last edit: 11 Jan 2014 08:26 by rbe2012. Reason: wrong attachment
11 Jan 2014 09:42 #18357 by vlad_vy
Replied by vlad_vy on topic 4.0.1 - Devo 7e - Blade NanoCPX Problem
Are you sure that you bound to NanoCPX as Computer Radio? With rudder to the right.
11 Jan 2014 11:51 #18359 by Alexander
Hi Guys,
first of all thanks for your help. I finally figured out the problem!! :-)
The problem was with the trims. When I checked the servo monitor with all sticks in neutral position, the servo monitor showed a rudder value of 12 and an aileron value of 5. Then I set the subtrims of the aileron and rudder channels so that both values are 0 in neutral stick position. Problem solved :-)
I remembered having the same problem with the Devo8s.. with 4.0.1 some subtrim must be applied to get a correct value of 0 in the servo monitor.
Someone had the same problem?
Kind regards,
Alexander
11 Jan 2014 12:29 #18360 by kreidler
Replied by kreidler on topic 4.0.1 - Devo 7e - Blade NanoCPX Problem
When I put the model.ini of your first posting into the 7e-emulator I cannot see any applied subtrims or trims.
Have you calibrated the sticks after installation of the firmware or do you use an old or different tx.ini?
11 Jan 2014 18:34 #18370 by Alexander
Thanks, I think calibrating sticks should do the trick :-)
Time to create page: 1.311 seconds
