Driver for STM32 DFU
11 Jan 2014 05:28 - 11 Jan 2014 06:55 #18348 by Timecop67
Driver for STM32 DFU was created by Timecop67
I am trying to flash my Devo 10 with deviation but my Windows 7 64 bit.... does not recognize controller. Program cannot locate the driver for STM32 DFU. Can someone give me a link so I can get it downloaded? Is this an error in the DfuSe program?
Had to let Windows do a search online to find a suitable driver for STM32 DFU....everything seems to work now.
Last edit: 11 Jan 2014 06:55 by Timecop67.
11 Jan 2014 06:54 #18349 by vlad_vy
Replied by vlad_vy on topic Driver for STM32 DFU
You can try install driver manually from programm folder - \devention Upgrade Tools\Driver\
11 Jan 2014 09:40 #18356 by RandMental
Replied by RandMental on topic Driver for STM32 DFU
You can also try to remove all USB devices connected to the PC and then reboot.
Then connect only the USB cable to the Devo TX, that would normally allow the driver to load correctly.
There after you can reconnect your other USB devices.
11 Jan 2014 13:08 #18362 by sonicserve
Replied by sonicserve on topic Driver for STM32 DFU
You need to install the driver manually. The firmware update tool comes with a installation guide in PDF format. It is installed automatically to the installation folder. For your convenience, I attach it here. It documents the process on how to install the driver.
Time to create page: 0.126 seconds
