Mode 1 to 2 switch
- aliosa27
14 Jan 2014 19:31 #18506
by aliosa27
Mode 1 to 2 switch was created by aliosa27
So hobbyking sent me a mode 1 devo7e, and I switched it to mode 2 following the manual. the only thing i didnt do was the electronic switch in the stock firmware. I had flashed it to deviation before doing do. In the deviation menu i switch it to mode 2 and the right stick still acts like throttle, if i switch it to mode 1 then the left stick acts as throttle......
Has anyone else seen this?
- WheresWaldo
- aliosa27
14 Jan 2014 21:41 #18509
by aliosa27
Replied by aliosa27 on topic Mode 1 to 2 switch
Throttle and Rudder should be my left stick when i select mode 2 but throttle and rudder are on the left stick when i select mode 1 and when mode 2 is selected, throttle and Aileron are on the right stick...see the flip floppyness here..
- kreidler
15 Jan 2014 22:06 #18544
by kreidler
Replied by kreidler on topic Mode 1 to 2 switch
Setting the switch in the stock firmaware or not does not matter.
Do you use the standard GUI or the advanced GUI alrready?
Have you copied the files to the tx from a fresh install or already 'used' ones?
Time to create page: 0.211 seconds
- Mode 1 to 2 switch
