Potentiometers Walkera Devo 10, or changing stick?
- matrixFLYER
30 Jan 2014 01:37 - 31 Jan 2014 20:13 #19402
by matrixFLYER
Potentiometers Walkera Devo 10, or changing stick? was created by matrixFLYER
Hi. Hi read that is possible to put Taranis sticks on Turnigy 9X.
I'm asking if is possible to get different stick on Devo 10 because this can be one solution to fix bad potentiometer on stock sticks since the potentiometers for Devo 10 aren't available.
Last edit: 31 Jan 2014 20:13 by matrixFLYER.
30 Jan 2014 03:14 #19404
Replied by vlad_vy on topic Taranis/9XR sticks to Devo 10 is it possible?
- matrixFLYER
30 Jan 2014 10:31 #19413
by matrixFLYER
Replied by matrixFLYER on topic Taranis/9XR sticks to Devo 10 is it possible?
Wow thank you!!!
- sbstnp
30 Jan 2014 14:34 #19419
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Replied by sbstnp on topic Taranis/9XR sticks to Devo 10 is it possible?
Good find Vlad
vlad_vy wrote: Pots for Walkera Tx
www.aliexpress.com/item/BELLA-Japanese-N...10MM/1362880288.html
www.aliexpress.com/item/SA-Japanese-NOBL...10MM/1302569488.html
Devo 10 + 4in1
- matrixFLYER
30 Jan 2014 14:35 #19421
by matrixFLYER
Only 10 pieces/lot
- WheresWaldo
30 Jan 2014 14:37 #19422
by WheresWaldo
Replied by WheresWaldo on topic Taranis/9XR sticks to Devo 10 is it possible?
Still cheaper than buying a new Devo10, you could always sell the rest here or on rcgroups.matrixFLYER wrote: Only 10 pieces/lot
30 Jan 2014 14:51 #19424
Be aware, you can easily damage them at time soldering.
- matrixFLYER
30 Jan 2014 14:52 - 30 Jan 2014 14:56 #19425
by matrixFLYER
For the hot temperature?
Are we sure that the pot of Devo 10 are the same?
I made a photo:
www.dropbox.com/s/m7rpsw4yp9epdq1/IMG_20140125_233935.jpg
If they sometimes works and sometimes doesn't work can be a potentiometer problem? Before buying 10 of them I want to be more sure. Or maybe it's the motherboard?
vlad_vy wrote: Be aware, you can easily damage them at time soldering.
I made a photo:
Last edit: 30 Jan 2014 14:56 by matrixFLYER.
- NoMaster
31 Jan 2014 18:45 - 31 Jan 2014 18:53 #19522
by NoMaster
What is the difference between the two types ?
Edit: uups, only different sellers ... sry
Replied by NoMaster on topic Taranis/9XR sticks to Devo 10 is it possible?
Last edit: 31 Jan 2014 18:53 by NoMaster.
- micro
31 Jan 2014 18:48 - 31 Jan 2014 20:42 #19524
by micro
Replied by micro on topic Taranis/9XR sticks to Devo 10 is it possible?
Thanks for the link Vlad although that's a pretty offensive price per a potentiometer worth less than £1 and £10 post when they fit in a letter post no issue.
EDIT - I was wrong, it's 10 pots for that price. Not offenisve at all,m just not at all cheap. I dearly love teh walkera gimbals so i'm in for a few years worth of sprares. I owe you a drink Vlad
I bought some taranis gimbals and some aurora 9 to try but so far have only tried and failed fitting them to a 9xr as a french shop stated they were infact a droip in. Pure lies, not even without modifications to the overlapping fascia holes for gimbals as they are differnt size.
I never got round to fitting them in the Walkera as although very smooth gimbals they both seem to be, the tension adjustment does not go low enough for me. With both of these gimbals if you lower the tension to the point I have my walkera at there is a dead zone in the middle with no spring - get rid of that tension and its too stiff for me to be able to do prioflips, piro circuits or any subtle cyclic rotations with finesse. It even shut out the taranis for me if thats the score,
Still in corespondance with few suppliers uk and not and also walkera but waiting due to chinese new year. Slowly, slow... l.. zz zz zz
Incidentally, the only other gimbals I have used that go low enough for me are the frsky th9x and the wee 7e I don't like for flying non micros at all due to the tiny gimbals. There is however stacks of space in the 8s so id be suprized if they were not modable if you were down with stiff sticks.
Last edit: 31 Jan 2014 20:42 by micro.
- matrixFLYER
31 Jan 2014 20:20 - 31 Jan 2014 20:22 #19527
by matrixFLYER
Replied by matrixFLYER on topic Potentiometers Walkera Devo 10, or changing stick?
Updated the title of the thread now it's more "focused" on the thread hearth
Anyone wants to make a group buy for 1 lot of ten potentiometers? My Devo 10 is working after the last disassembly so I would take a couple of spare potentiometers...
Last edit: 31 Jan 2014 20:22 by matrixFLYER.
- matrixFLYER
03 Feb 2014 01:53 #19762
by matrixFLYER
Is Devo 7 100% compatible for potentiometer and sticks? Maybe a better bargain for spare parts...
Time to create page: 0.812 seconds
- Potentiometers Walkera Devo 10, or changing stick?
