Potentiometers Walkera Devo 10, or changing stick?
30 Jan 2014 01:37 - 31 Jan 2014 20:13 #19402 by matrixFLYER
Hi. Hi read that is possible to put Taranis sticks on Turnigy 9X.
I'm asking if is possible to get different stick on Devo 10 because this can be one solution to fix bad potentiometer on stock sticks since the potentiometers for Devo 10 aren't available.
Last edit: 31 Jan 2014 20:13 by matrixFLYER.
30 Jan 2014 10:31 #19413 by matrixFLYER
Replied by matrixFLYER on topic Taranis/9XR sticks to Devo 10 is it possible?
Wow thank you!!!
30 Jan 2014 14:34 #19419 by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
30 Jan 2014 14:35 #19421 by matrixFLYER
Only 10 pieces/lot :(
30 Jan 2014 14:37 #19422 by WheresWaldo
Replied by WheresWaldo on topic Taranis/9XR sticks to Devo 10 is it possible?
matrixFLYER wrote: Only 10 pieces/lot :(
Still cheaper than buying a new Devo10, you could always sell the rest here or on rcgroups.
30 Jan 2014 14:51 #19424 by vlad_vy
Replied by vlad_vy on topic Taranis/9XR sticks to Devo 10 is it possible?
Be aware, you can easily damage them at time soldering.
30 Jan 2014 14:52 - 30 Jan 2014 14:56 #19425 by matrixFLYER
vlad_vy wrote: Be aware, you can easily damage them at time soldering.
For the hot temperature?
Are we sure that the pot of Devo 10 are the same?
I made a photo:
www.dropbox.com/s/m7rpsw4yp9epdq1/IMG_20140125_233935.jpg
If they sometimes works and sometimes doesn't work can be a potentiometer problem? Before buying 10 of them I want to be more sure. Or maybe it's the motherboard?
Last edit: 30 Jan 2014 14:56 by matrixFLYER.
31 Jan 2014 18:45 - 31 Jan 2014 18:53 #19522 by NoMaster
Replied by NoMaster on topic Taranis/9XR sticks to Devo 10 is it possible?
vlad_vy wrote: Pots for Walkera Tx
www.aliexpress.com/item/BELLA-Japanese-N...10MM/1362880288.html
www.aliexpress.com/item/SA-Japanese-NOBL...10MM/1302569488.html
What is the difference between the two types ? :huh:
Edit: uups, only different sellers ... sry :whistle:
Last edit: 31 Jan 2014 18:53 by NoMaster.
31 Jan 2014 18:48 - 31 Jan 2014 20:42 #19524 by micro
Thanks for the link Vlad although that's a pretty offensive price per a potentiometer worth less than £1 and £10 post when they fit in a letter post no issue.
EDIT - I was wrong, it's 10 pots for that price. Not offenisve at all,m just not at all cheap. I dearly love teh walkera gimbals so i'm in for a few years worth of sprares. I owe you a drink Vlad :)
I bought some taranis gimbals and some aurora 9 to try but so far have only tried and failed fitting them to a 9xr as a french shop stated they were infact a droip in. Pure lies, not even without modifications to the overlapping fascia holes for gimbals as they are differnt size.
I never got round to fitting them in the Walkera as although very smooth gimbals they both seem to be, the tension adjustment does not go low enough for me. With both of these gimbals if you lower the tension to the point I have my walkera at there is a dead zone in the middle with no spring - get rid of that tension and its too stiff for me to be able to do prioflips, piro circuits or any subtle cyclic rotations with finesse. It even shut out the taranis for me if thats the score, :(
Still in corespondance with few suppliers uk and not and also walkera but waiting due to chinese new year. Slowly, slow... l.. zz zz zz
Incidentally, the only other gimbals I have used that go low enough for me are the frsky th9x and the wee 7e I don't like for flying non micros at all due to the tiny gimbals. There is however stacks of space in the 8s so id be suprized if they were not modable if you were down with stiff sticks.
Last edit: 31 Jan 2014 20:42 by micro.
31 Jan 2014 20:20 - 31 Jan 2014 20:22 #19527 by matrixFLYER
Replied by matrixFLYER on topic Potentiometers Walkera Devo 10, or changing stick?
Updated the title of the thread now it's more "focused" on the thread hearth ;)
Anyone wants to make a group buy for 1 lot of ten potentiometers? My Devo 10 is working after the last disassembly so I would take a couple of spare potentiometers...
Last edit: 31 Jan 2014 20:22 by matrixFLYER.
03 Feb 2014 01:53 #19762 by matrixFLYER
Is Devo 7 100% compatible for potentiometer and sticks? Maybe a better bargain for spare parts...
