Devo8S and 2801Pro Rx issue.
12 Feb 2014 20:41 - 12 Feb 2014 20:43 #20204 by Blayd
Devo8S and 2801Pro Rx issue. was created by Blayd
I'l try not to be too long winded here.
I've had 2 Devo8S Tx's for almost a year, and now that its winter upgrade time, I am planning on switching from my trusty 2801Pro Tx's to the Devo8S Tx's. I have bought 802Rx's for all my heli's..(4 of them ) but I was hoping to just use the already installed 2801Pro Rx's in them.
I've had Deviation installed on both Tx's for almost a year, ( v3.0 ) fooled with it a bit, but now I'm trying to get the heli's set up.
The heli's consist of my 2 Trex 500's, and HC500 and a Trex 700E that all fly on the 2801Pro right now, ( for the last 3 1/2 years..rock solid..)
When I went to bind to the first 2801 Pro Rx, I first had to erase the fixed ID, then it finally would bind.
PROBLEM...the servos are wrong. I'm using the standard GUI, the advanced is beyond me.
The elevator servo is now acting like my aileron servo, and vise versa.
Is this a common situation? Must I move the servos around in the Rx to get the right movements?
Sorry for the noob questions.
Thanks for any help.
Devo 8S
Trex500ESP
Trex500ESP (Belted tail)
HC500SE
Trex700N2E
Last edit: 12 Feb 2014 20:43 by Blayd.
12 Feb 2014 21:26 #20206 by FDR
Replied by FDR on topic Devo8S and 2801Pro Rx issue.
Are you sure the stick mode is right?
12 Feb 2014 22:27 #20210 by Blayd
Replied by Blayd on topic Devo8S and 2801Pro Rx issue.
Yes sir....
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
  • rbe2012
  • rbe2012's Avatar
13 Feb 2014 06:33 #20222 by rbe2012
Replied by rbe2012 on topic Devo8S and 2801Pro Rx issue.
The servo directions could have been changed in the old 2801-config. Have you looked there for changes to the default you must apply in the new configuration too?
Have you selected the correct swash plate type (120/120x)?
13 Feb 2014 19:24 #20239 by Blayd
I started by setting the settings in the Devo8S, now running 4.0.1, to the same settings as were in the 2801Pro Tx. Things like servo reverse, gyro gain, etc...but never got very far after noticing that the servos arent right.
Yes, swash is 120° 3 servo.
After working in the advanced menu for awhile, I was able to get the elevator servo working as the elevator, the ail as ail, and the pitch as the pitch, but no throttle response. I just dont seem to be able to understand the advanced GUI, and was hoping the standard GUI would work.
Since I'm not running any other protocol other then Walkera, I guess I'm going to just switch the Rx's from the 2801Pro's that are in the heli's at the moment, to the 802Rx's I have. I was hoping that I'd be able to use Deviation and just keep the 2801Pro Rx's in the heli's.
Thanks though.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
14 Feb 2014 08:23 - 14 Feb 2014 08:24 #20260 by rcminiman
Replied by rcminiman on topic Devo8S and 2801Pro Rx issue.
Im gonna be doing the same this weekend. Will be keeping both my 2801 and 2601 protocol rx's.
I will let you know how I get on...
Last edit: 14 Feb 2014 08:24 by rcminiman.
14 Feb 2014 18:52 - 14 Feb 2014 18:53 #20274 by Blayd
I'd appreciate it. I'd really like to be able to learn more on using the advanced GUI, but the manual reads like calc, and there doesnt seem to be any "how to" vids for learning. How cool would it be to have vids on how to.. set up complex mixers, ccpm, etc.
I'm still fooling with it, the standard GUI just wont set up the servos like the 2801 Pro Rx, but I'm still very lost in figuring this out. I'm no dummy, I build my own computers, write code for light ray-tracing, animation, I just happen to be old, and do better with comparitive learning.. do this, this happens, change this, you can do this.. etc...
I am fully confident in Deviation, just not myself....
I'll be checking back...meanwhile, I'm going to go and see if I can make heads or tails of the Advanced GUI, since this seems to be the way to get what I want. I have three 500's and a 700 I'd like to get Deviation to run the 2801Pro Rx's on. Otherwise, It's back to Devention and the 802Rx's.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
Last edit: 14 Feb 2014 18:53 by Blayd.
14 Feb 2014 21:04 #20280 by Kdean
Replied by Kdean on topic Devo8S and 2801Pro Rx issue.
Hey Blayd, good to see you here. The advanced gui is pretty cut and dry, to the point, DIY, type of interface. Once you learn the terms and what they do, you will find it very easy to setup more complex mixes and get things to do exactly what you want.
Coming from the 2801pro tx I know its a totally different approach than what your used to, but it explains alot of the things we would normally take for granted. Like the swash mixing for example.
I know you'll get it, your in the right place.
15 Feb 2014 17:35 #20314 by Blayd
Good to see you too KMan.
Devo 8S
Trex500ESP
HC500SE
Trex700N2E
