Devo 8 Screen Failure
18 Feb 2014 01:15 #20489 by HeliPilot70
Devo 8 Screen Failure was created by HeliPilot70
Hi All,
I recently dusted off my Devo 8 transmitter and installed the latest build. All works perfectly (thank you to all involved), but I now have 5 or 6 vertical blank lines on the left hand side of the screen. There are persistent over all menu screens.
Has anyone else seen this issue and does anyone have a suggested solution?
Thanks,
HeliPilot70
  • rbe2012
  • rbe2012's Avatar
02 Mar 2014 10:50 #21073 by rbe2012
Replied by rbe2012 on topic Devo 8 Screen Failure
Did you see this with the stock firmware too? If so, your tx (lcd) will be broken.
If not: do you see any labels in the battery compartment? We had a change in LCD controller earlier which has lead to different labels there.
Time to create page: 0.206 seconds
