:( New Devo 10 arrived DOA, any experts around?
22 Feb 2014 01:55 #20722 by microheli
All,
First time poster here with a new Devo 10, was planning to install deviation, but radio boots up "dead" out of the box. Here's a video:
Is this a known failure state, fixable or send back?
Any expertise appreciated.
22 Feb 2014 03:03 - 22 Feb 2014 03:04 #20723 by PhracturedBlue
Replied by PhracturedBlue on topic :( New Devo 10 arrived DOA, any experts around?
It isn't broken.
It is flashed with Chinese language and is telling you to move the switches to the safe positions (probably all up, with throttle all the way down.
I am not sure if reflashing with the latest Walkera firmware will get it back to English or not, but if not someone will be able to tell you how to do it.
Make sure it is working as expected before putting Deviation on it.
Last edit: 22 Feb 2014 03:04 by PhracturedBlue.
22 Feb 2014 12:28 #20734 by FDR
Ensure the FMODE switch is in 0 position, and try to lower the right stick to the lowest position too, because the tx might be setup for mode 1...
22 Feb 2014 15:56 #20746 by microheli
Replied by microheli on topic :( New Devo 10 arrived DOA, any experts around?
Thanks everyone - I wasn't going to figure this out on my own.
I don't have any models to test this with - I have a v911 and a v262, both of which I need to solder chips into the TX and install deviation in order to use.
Maybe I can find a nearby flying club to test it on someone else's stuff before I do the firmware flash.
Thanks again!
22 Feb 2014 16:13 #20747 by PhracturedBlue
You don't need to test that the tx is fully functional before installing Deviation, but it is not a bad idea to make sure the menus work and otherwise is ok before installation. That way if you do need to return it you don't need to dealw with flashing it back. Once you install the extra chips you won't be able to return it, so make sure you don't see any issues with it. Getting the menus into English should not be difficult. The problem is that the manual doesn't tell you how many presses you need. You ned to do:
'Ent'->Main menu
'Down' to System menu then 'Ent' ->System menu
'Down' to 'Language' then 'Ent'-> Language menu
Select 'English'
But I don't have the stock firmware installed, so I don't know how many times you need to press 'Down' to get to the right menu.
Or you could just install Deviation immediately and test functionality with Deviation (again, just making sure switches/sticks work properly). It is unlikely that there are any issues with your Tx if you get the failsafe screen you showed in your video. But of course, in the end it is up to you.
22 Feb 2014 16:42 - 22 Feb 2014 16:50 #20750 by Tom Z
I have the Devo 10 with factory firmware.
At the home screen Press ENT, Down, Down, ENT, ENT, English is the top one, select it Press ENT.
Here is the newest version factory firmware for the Walkera Devo 10.
File Attachment:
File Name: Devo10-0.7A-100mw.zip
File Size:163 KB
Last edit: 22 Feb 2014 16:50 by Tom Z.
23 Feb 2014 18:26 #20796 by microheli
So with everyone's help I got my TX to switch on and via youtube and button pressing I got it switched to English language. It's running firmware .7A and library version .2. So I guess I'm good to go to Deviation...
Thanks to everyone for their help.
Time to create page: 0.392 seconds
