ProtoX Hack
23 Feb 2014 05:42 - 25 Feb 2014 06:47 #20777 by Birdman
ProtoX Hack was created by Birdman
Thrown together to see if it will work, and it does. Time to tidy things up.
ProtoX was not enjoyable to fly with original tx. This transformed the quad.
It is now better than wife's Ladybird which I thought was the best thing ever for poking around the house.
Calibrated and setup with some rates and expo it is sweet as.
Didn't want to wait for module so hacked original tx. Seems it have an amp of some description.
1) black wire scs
2) white wire sck
3) red wire mosi
6) green wire +3.3V
5) black gnd
Bm
Last edit: 25 Feb 2014 06:47 by Birdman.
23 Feb 2014 08:02 - 23 Feb 2014 09:31 #20783 by Birdman
Replied by Birdman on topic ProtoX Hack
Range, still had signal at 70 meters @ 30mw. I give up at that point as I consider that more than enough.
Bm
Last edit: 23 Feb 2014 09:31 by Birdman.
23 Feb 2014 10:19 #20785 by John-Boy
Replied by John-Boy on topic ProtoX Hack
Thanks for showing the way to use this. ;)
24 Feb 2014 22:42 #20842 by stringrazor
Replied by stringrazor on topic ProtoX Hack
Nice! So this was a literal "hack", i.e. you actually cut down the board? Did you take any other pics of the cut?
25 Feb 2014 06:29 - 25 Feb 2014 06:44 #20850 by Birdman
Yes cut down the board. No other pics of cut, but if you look at pics already posted you should see where to go. If not let me know.
Bm
edit: I cut a bit to close to 3.3V rail (lower edge of board in pics), you may want to leave a little more room.
Last edit: 25 Feb 2014 06:44 by Birdman.
25 Feb 2014 06:34 - 25 Feb 2014 06:46 #20851 by Birdman
Follow V911 module installation instructions
1) black wire scs
2) white wire sck
3) red wire mosi
6) green wire +3.3V
5) black gnd
Bm
Last edit: 25 Feb 2014 06:46 by Birdman.
25 Feb 2014 08:10 - 25 Feb 2014 08:12 #20853 by Birdman
Circuit
Enable 7501 and amp in tx ini
Last edit: 25 Feb 2014 08:12 by Birdman.
25 Feb 2014 14:24 #20860 by PhracturedBlue
Replied by PhracturedBlue on topic ProtoX Hack
Thanks. I moved your ini to a new thread in the models section
Time to create page: 0.069 seconds
