Using Pheonix rc simulator and Devo-10 ??????
04 Mar 2014 18:14 #21192 by Hondawasaki
:angry: I just cannot get it to work correctly.
I have a DEVO-10 tx and am using dev 4 ( the latest version)
First off is the correct sim cable mod or adaptor ...... sim has a stereo 1/8 male and DEVO uses a mono 1/8 male ....
I have made connection with the sim but cannot get a working configuration.
it always mixes the elev and throttle .... the tx is in mode 2 .....
I am willing to hack my cables up if some one knows how to wire them together to function properly.
I have tried the DEV 3 Phoenix file ... no go .
09 Mar 2014 08:41 #21386 by sowhat2112
Replied by sowhat2112 on topic Using Pheonix rc simulator and Devo-10 ??????
Just ordered Phoenix to use with my Devo 10 anyone else having problems like this gentlemen?
09 Mar 2014 08:53 #21388 by RandMental
Replied by RandMental on topic Using Pheonix rc simulator and Devo-10 ??????
Set up correctly on PPM-out you should have no issue, whatever Deviation/Phoenix versions you use. No cable moods necessary.
13 Mar 2014 02:13 #21515 by ran_k
RandMental wrote: Set up correctly on PPM-out you should have no issue, whatever Deviation/Phoenix versions you use. No cable moods necessary.
noob here :P
can you plz help me cuz i couldn't find how to select the PPM-out?
Thank
13 Mar 2014 03:30 #21518 by PhracturedBlue
Replied by PhracturedBlue on topic Using Pheonix rc simulator and Devo-10 ??????
Go to the Model Setup menu, scroll down to 'Protocol (on the Devo7e/10 it'll just say 'DEVO') change it to 'PPM'. Press 'Re-Init' and you should be good to do.
13 Mar 2014 04:35 - 13 Mar 2014 04:36 #21519 by ran_k
PhracturedBlue wrote: Go to the Model Setup menu, scroll down to 'Protocol (on the Devo7e/10 it'll just say 'DEVO') change it to 'PPM'. Press 'Re-Init' and you should be good to do.
Thank you!
so let me see if i got it, i need to set up a model that is only for using
the simulator right?
Last edit: 13 Mar 2014 04:36 by ran_k.
13 Mar 2014 05:16 #21520 by PhracturedBlue
correct
15 Mar 2014 04:31 - 15 Mar 2014 05:42 #21558 by Hondawasaki
Replied by Hondawasaki on topic Using Pheonix rc simulator and Devo-10 ??????
File Attachment:
File Name: model1_201...14-2.ini
File Size:4 KB
You will have to make a controller profile in Phoenix.
Go through the Tx setup ignoring the Gear and Flaps for now.
then after saving the setup go back to the new profile and edit it in advanced mode.
and highlight the reverse box for the following
Cyclic roll
Cyclic Pitch
Tail rotor
Left elevator
Right elevator
Left aileron
Leave all the other boxes unchecked ..
and enjoy
this is DEV4 on phoenix 5..
helicontrols
RUD DR1= throttle hold
Fmode 0 = sport flight,30 expo ,and only 10%negative pitch
Fmode 1 = Idle up, 15 expo
Fmode2 = Idle up , 0 expo
ALE DR0 = correct for heli
airplane controls
Aile DR1 for planes
MIX1=flaps
Gear= landing gear
Last edit: 15 Mar 2014 05:42 by Hondawasaki.
16 Mar 2014 20:18 #21601 by matrixFLYER
Replied by matrixFLYER on topic Using Pheonix rc simulator and Devo-10 ??????
the phoenix 5 configuration file for transmitter would be useful xD
25 Mar 2014 21:17 #21833 by olongapso
Replied by olongapso on topic Using Pheonix rc simulator and Devo-10 ??????
hi guys, I have a new devo10 software ver 0,7A and library ver 0,2. this tx doesn't work with phoenix and I'm not able to set PPM protocol. I don't find protocol and re-init menù.
could you help me with other instruction?
25 Mar 2014 22:46 #21834 by victzh
This forum is about the Open Source firmware for Devo - Deviation. You have the original firmware, which is totally different and has different user interface and options. The PhracturedBlue's answer addressed Deviation solution for this.
26 Mar 2014 00:19 - 26 Mar 2014 00:22 #21837 by Hondawasaki
@ matrix flyer
its working in 5 ( with dev 4.0.1)
.load the last .ini file (in this thread)then go into phoenix and setup a new controller profile ... when all is done you may need to edit the controls in phoenix reverse a couple things ...and assign channels 5-7-8 to the chosen functions.
when phoenix ask for gear input use the gear1 position and use ali dr for the other input it ask for when setting up the new TX profile .
(you dont need to do anything for these controls)
.the file has the safty switch as RUD DR1 ..meaning no throttle
and fmode 0 is sport mode 30% expo ....fmode1 is stunt mode with expo
Fmode 2 is full 100% everything no expo
Last edit: 26 Mar 2014 00:22 by Hondawasaki.
26 Mar 2014 08:42 #21843 by olongapso
victzh wrote: This forum is about the Open Source firmware for Devo - Deviation. You have the original firmware, which is totally different and has different user interface and options. The PhracturedBlue's answer addressed Deviation solution for this.
ok, tks, so I need to update my firmware.
do you think if it is possible use devo10 with phoenix with original firmware?
26 Mar 2014 11:06 #21846 by Mmon77
Not according to the PhoenixRC website:
Please note that the following transmitters are not supported:
• USB controller devices and joysticks
• Spektrum DX7 "SE" version (This radio has no training output for R/C simulators)
• Hobbyzone transmitters and any transmitter included with ParkZone or E-Flite Ultra Micro products
• All Walkera except 2401, 2601, 2402, 2602 and 2801 (see above)
• Any other transmitter without a compatible training port
26 Mar 2014 11:16 #21847 by RandMental
I am using phoenix with two Devo8s TX'es - one with Deviation 4.01 and the original Devo firmware - no issues.
26 Mar 2014 13:08 #21854 by olongapso
RandMental wrote: I am using phoenix with two Devo8s TX'es - one with Deviation 4.01 and the original Devo firmware - no issues.
and with original firmware you use mono or stereo jack? any particular configuration?
27 Mar 2014 18:09 #21889 by olongapso
I have installed deviation. now phoenix works with my devo10.
only a problem: power stick is like on/off command. hely get command only when stick stay at 50% of stroke and get 100% of signal that became 0% below 50% of stick stroke.
i don't know.
thanks
luca
27 Mar 2014 19:33 - 27 Mar 2014 19:35 #21893 by The Deviator
Replied by The Deviator on topic Using Pheonix rc simulator and Devo-10 ??????
Hi o spagnolo !
Try going through the Phoenix calibration menu (System => Your Transmitter) , OR the Setup New Transmitter menu.
Last edit: 27 Mar 2014 19:35 by The Deviator. Reason: corrected typo's / grammar / layout
29 Mar 2014 18:05 #21937 by RandMental
Mine work with the Stereo connector
29 Mar 2014 20:18 #21939 by The Deviator
R/C buddy box plugs/ pin assignment : www.mftech.de/buchsen_en.htm
Time to create page: 1.477 seconds
