Using Pheonix rc simulator and Devo-10 ??????
- olongapso
05 Apr 2014 07:04 #22141
by olongapso
Replied by olongapso on topic Using Pheonix rc simulator and Devo-10 ??????
ok guys, now my devo 10 works with stereo connection. issue was my error during calibration. now works only stick but doesn't work others channel... I have to work on
- Hondawasaki
20 Apr 2014 16:29 - 20 Apr 2014 16:30 #22603
by Hondawasaki
Replied by Hondawasaki on topic Using Pheonix rc simulator and Devo-10 ??????
setup anew controller on phoenix again .... this is the PIA part ... if it isnt done right you will not get the flaps and gear working ... i use the gear and mix switches when phoenix ask to toggle switches to get those channels working
.. dont flip any other ones ..fmode,aile dir. and rud dr are programmed n my mix to give you ( fmode ) sportmode,stunt mode,full everything
(aile dr ) reverses aileron for flying planes
(rud dr ) is throttle cut for crashing and practicing auto's
Last edit: 20 Apr 2014 16:30 by Hondawasaki.
- The Deviator
21 Apr 2014 17:28 - 21 Apr 2014 17:38 #22633
by The Deviator
Replied by The Deviator on topic Using Pheonix rc simulator and Devo-10 ??????
I see no "PIA" : once calibration is done, it is done and set ...
For AIL, no need for a TX switch : just REVERSE the appropriate AIRCRAFT AIL channel in the "EDIT PROFILE -> detailed" menu (CTRL+C then "edit => detailed") ...
Hope this helps.
Hope this helps.
Last edit: 21 Apr 2014 17:38 by The Deviator. Reason: corrections, layout
Time to create page: 0.703 seconds
- Using Pheonix rc simulator and Devo-10 ??????
