Updated Module Installation instructions
11 Mar 2014 03:44 #21438 by PhracturedBlue
Updated Module Installation instructions was created by PhracturedBlue
I'm updating the module installation instructions to add documentation for the 'Universal Module'. I've moved the Module Installation instructions to the Wiki rather than keeping it as a PDF. The Wiki seems better oriented for this task, and allows me to use higher resolution images and links to better organize the information. I am not done yet, but I have incorporated all of the information that was in the original PDF I believe.
The new page can be found here:
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleInstallation
I've followed Daryoon's lead and color-coded all connections, and have added higher resolution images of all the modules I have access to.
I'd appreciate any feedback on it before I proceed much further.
11 Mar 2014 06:23 #21448 by SeByDocKy
Replied by SeByDocKy on topic Updated Module Installation instructions
PhracturedBlue wrote: I'm updating the module installation instructions to add documentation for the 'Universal Module'. I've moved the Module Installation instructions to the Wiki rather than keeping it as a PDF. The Wiki seems better oriented for this task, and allows me to use higher resolution images and links to better organize the information. I am not done yet, but I have incorporated all of the information that was in the original PDF I believe.
Hi PB,
I am a little bit confused with pinout described in this WiKi. I don't have (yet) the universal module, just the A7105-500 and a nRF24L01+PA+LNA. For example, you wrote "*4.0.1 and earlier: Connect 8->GND and 9->3.3V. Leave 6 and 7 floating". But I have this pinout and using the last NB.... and it's working perfectly. Do you mean that I have update wiring in my installation ?
11 Mar 2014 13:44 #21454 by PhracturedBlue
Replied by PhracturedBlue on topic Updated Module Installation instructions
The nightly builds work fine with the 'old' wiring system. However, if you use the new wiring diagram (6->9, 7->8) or if you use the universal module (which does this for you) Deviation will be able to shutdown the A7105 PA. I didn't check it as yet, but that should reduce power consumption when not in use. It also allows turning on the LNA, but I don't thin we have any protocols using telemetry with A7105.
11 Mar 2014 13:53 #21455 by vlad_vy
Replied by vlad_vy on topic Updated Module Installation instructions
Hubsan protocol has basic telemetry.
12 Mar 2014 20:11 #21508 by suzali
Replied by suzali on topic Updated Module Installation instructions
I'm a little confused...
The color code in the .../wiki/ModuleList does not match the color code in the picture .../wiki/Devo7eModuleInstall
MISO is blue, MOSI is gray on the picture and vice versa in the moduleList...
Which is right ?
12 Mar 2014 20:24 #21509 by PhracturedBlue
Thanks. The text label on the Devo7e was wrong (the colors were correct). I've fixed the image to be consistent now.
13 Mar 2014 19:33 - 13 Mar 2014 19:47 #21529 by IMback!
Replied by IMback! on topic Updated Module Installation instructions
Ok, is the wireing noted someware? I have rxen wired to vdd atm. works fine with long hubsan telemetry range. But i will change it asap if its undefined.
EDIT: found it
EDIT2:
there are some mistakes in Modulelist WIKI page. For the skyartec module it says: "*4.0.1 and earlier: Connect 11->3.3v and 12->GND. Leave 7 and 8 floating" but the module only has 10 pins. same thing for XL2500. I dont know what its suposed to be
Also i find the colors very confusing i cant figure out what rx_en schould be connected to on the XL7105
Last edit: 13 Mar 2014 19:47 by IMback!.
13 Mar 2014 20:09 #21530 by PhracturedBlue
I moved your reply to the proper thread.
I've fixed the items you listed.
The 'Notes' field describes the connections in addition to the standard 6 pins to the Tx.
Generally, the colors are:
connect 'Orange' pins together
connect 'Dark Grey' pins together
leave 'clear' pins alone.
But the notes in the table should clarify the connections
17 Mar 2014 22:37 #21631 by goebish
Replied by goebish on topic Updated Module Installation instructions
PhracturedBlue wrote: It also allows turning on the LNA, but I don't thin we have any protocols using telemetry with A7105.
Hubsan X4 protocol has telemetry since 4.0.1, should I modify the code for the new wiring ?
18 Mar 2014 00:46 #21634 by PhracturedBlue
It has already been done
18 Mar 2014 08:59 #21642 by goebish
OK thanks, my Devo 10 (with XL7105-D03) is an energy hog, I hope it will be better with the new wiring :)
Time to create page: 1.002 seconds
