Devo 7e + A7105PA + Range mod current draw.
14 Mar 2014 18:34 #21552 by Fulch
Have just rewired A7105PA module as per PB's latest install guide to measure if TX current draw was any less than the original wiring method when A7105 was not active.
Running recent NB and range modded inbuilt CYRF module with backlight off.
Old wiring / New wiring
100uW - 178mA / 100uW - 112mA
150mW - 199mA / 150mW - 133mA
Looks like my batteries should be lasting longer thanks PB. :)
Not sure if this is normal but when the A7105PA module is active the range of it's current draw is much less than the CYRF module with either wiring method.
A7105PA active 100uW - 134mA, 150mW - 139mA.
Like some others have reported I also get a humming noise from the buzzer which appears more pronounced at higher TX power settings. When the hum is present the current draw increases by about 60mA and I can measure 1.2 Volts across the buzzer connections.
Moving any trim switch plus or minus can normally stop the hum, the associated current draw and voltage on the buzzer pins. It's like the buzzer is reset to a normal state by the beep produced in response to the trim switch.
It seems that after having to produce a sound i.e turning the controller on, using a trim switch, sometimes the buzzer is not shut off correctly, is this even possible?
Sorry for such a wordy first post and thank you to everybody supporting this project!
17 Mar 2014 01:20 #21607 by HappyHarry
Replied by HappyHarry on topic Devo 7e + A7105PA + Range mod current draw.
that's good info, thanks for sharing :)
though I am interested in what the different wiring method actually does to the module? and I've seen a couple of people have that buzzing issue with both 7105 and nrf modules when using high output settings but I've never came across it myself.
17 Mar 2014 02:02 #21609 by aMax
I have this buzzing issue without having installed any additional modules.
The range mod is not done up to now.
Any other fix than to use the trim every time?
18 Mar 2014 00:17 #21633 by Fulch
HappyHarry wrote: that's good info, thanks for sharing :)
If I understand PB's explanation correctly, the new wiring method makes it possible to turn off the A7105 power amp when the module is not active, to prolong TX battery life.
18 Mar 2014 00:58 #21635 by PhracturedBlue
Replied by PhracturedBlue on topic Devo 7e + A7105PA + Range mod current draw.
Fulch:
Can you check the difference in current draw when
1) starting with 'Flysky' and switching to 'DEVO'
2) starting with 'Hubsan' and switching to 'DEVO'
3) powering up in 'DEVO'
The 'low-power' code is not consistent on the A7105, and I'm interested how the different cases compare. I think case (2) should be the lowest power. If so, I will make the other cases behave the same as that.
18 Mar 2014 01:12 #21637 by Fulch
aMax wrote: I have this buzzing issue without having installed any additional modules.
Having read most of other peoples description of "their buzz" there does not appear to be a common set of conditions that cause it to occur. I first noticed it when I had the case open having just done the range mod.
It was after the rewire of the A7105 module and measuring the current draw that I realized that when the buzz was present the current draw was also higher.
My guess is and it is only a guess that the buzz is electrical noise picked up and relayed through the speaker which we hear only because the speaker is "on", when you get the speaker to produce a few beeps in response to a trim switch it seems to then switch "off". I still find that even once it has stopped if you need to use a trim whilst flying the buzz could well start again.
At this time turning the TX volume to zero and relying on vibration only is my best solution!
There is a recent bug report submitted by another user that may have the same root cause.
bitbucket.org/PhracturedBlue/deviation/i...ays-with-high-signal
18 Mar 2014 01:25 - 20 Mar 2014 17:36 #21638 by Fulch
PhracturedBlue wrote: Fulch:
Results are exactly as you predicted!
All measurements are taken with Sound, Backlight and Vibration turned off.
Case 1: 100uW - 184mA , 150mW - 226mA Checked this one twice to be sure.
Case 2: 100uW - 93mA , 150mW - 139mA
Case 3: 100uW - 98mA , 150mW - 146mA
Also tried Flysky -> Hubsan, Devo -> Hubsan, Power up -> Hubsan, in this case Power up - > Hubsan consumed least but only by 10mA.
With Hubsan protocol I can never measure more than 4mA difference fromm lowest Tx power to highest and have personally flown my X4 at 100uW power out to around 50 feet without losing bind.
Does this imply that the power output scaling of the A7105PA is not optimum when used with Hubsan protocol?
Last edit: 20 Mar 2014 17:36 by Fulch. Reason: Typo had meters meant feet
30 Mar 2014 19:23 #21959 by aMax
Can anyone, whoes 7e is humming, please verify. (no range mod)
Today i revised all my models and changed the powerrate down to 10mW.
Going down to at least 30mW will stop the noise in my Devo7e.
I think the original Devo7e firmware checked that and so there was no humming before.
BTW, to all who worked on the swithmod: Thank you for this marvelous result.
...3x2 :-))
24 Jun 2014 10:22 #24212 by Fernandez
Replied by Fernandez on topic Devo 7e + A7105PA + Range mod current draw.
I have this humming too, it is on all the modules, cc2500, a7105 and on the stock power modded CYRF.
The humming starts when you increasde output power. It seems not related to RF pickup as playing with the antenna pointing along the board, does not make hum softer or louder.
You can also see the display backlight of devo7e gets a bit of soft flickering when you have the high hum power setting.
I expect there might be a lane, which can't cope with the power or need a bigger capacitor.
I there a schematic of the devo-7e?
24 Jun 2014 10:58 - 24 Jun 2014 11:09 #24214 by Fernandez
The 3v3 supply voltage is clipping can't handle the demand.
At 10mW it is still 3v3 but dropping to 2v8 when at max power.
The small 3v3 regulator, is getting super hot, too hot too touch.
It needs to be replaced by a more capable one.
Last edit: 24 Jun 2014 11:09 by Fernandez. Reason: 3v3 regulator problem
24 Jun 2014 15:32 - 24 Jun 2014 16:05 #24216 by aMax
I switched the buzzer off and turned haptic on. All fine now.
This buzzing was allready there before range mod, it seem to be a 7E thing. My backlight was never flickering.
My measurements from the complett TX is:
CYRF 1 mW > 212 mA           A7105 1mW > 177.6 mA
     3 mW > 216 mA                 3mW > 178.6 mA
    10 mW > 224 mA                10mW > 181.6 mA
    30 mW > 242 mA                30mW > 188.0 mA
   100 mW > 256 mA               100mW > 189.3 mA
   150 mW > 260 mA               150mW no (100mW max)
The A7105 uses the old wiring but will be changed next time to 6/9
7/8.....while adding the NFR2401.
So these 260mA should be not so hard for the converter.
EDIT:
These 260 mA are max.
Starting in Devo mode it is only 250 mA and what is supprising, when I start with a model with activated telemetry, it draws only 197 mA at 1mW, 206 mA at 10 mW and 233 mA at 150 mW ..???
LCD is from 5 to off = 11mA and from 10 to off 18mA.
Last edit: 24 Jun 2014 16:05 by aMax. Reason: notation changed...;-)
24 Jun 2014 18:00 #24217 by Arakon
Replied by Arakon on topic Devo 7e + A7105PA + Range mod current draw.
What's this new wiring? I am using the basic A7105 without power amp, but my power draw feels pretty bad, my Eneloops (~2100 mAh) barely last 1.5-2 hours before dropping under 5V.
24 Jun 2014 18:58 #24218 by aMax
With Deviation 4.01 or earlier, it is advised to bind TXEN to VCC and RXEN to GND.
Works well, but when you use DEVO protocol, it seem that the board will not be put completely to sleep ...( or standby, really don`t known)
With the Nightly, it is said to connect TXEN to GIO1 and RXEN to GIO2.
I think, that due to better protocol handling this will save a little
battery power too.
24 Jun 2014 19:01 - 24 Jun 2014 19:02 #24219 by Fernandez
3v3 should stay 3v3, what ever the Tx power setting, that why there is a regulator.
3V3 Regulator seem oscillating going in current/temp limit, the psu voltage swing you indeed hear on the speaker as hum. A bigger Capacitor on powerline indeed humming weakens, but the problem is the small/hot regulator.
I do not know the schematic, or the type nr of regulator used.
AMS1117 doesn't match the pcb, could wire something in?
www.dx.com/p/ams1117-3-3v-ccl-components...-295891#.U6nJEo2KCZM
Last edit: 24 Jun 2014 19:02 by Fernandez.
24 Jun 2014 19:17 #24220 by Arakon
Hrm.. I don't have TXEN and RXEN on my module.. it's this one: www.ebay.com/itm/AMIC-A7105-Wireless-RF-...K-GFSK-/280953247359
I presume those pins are part of the power amp then, which I don't have.
24 Jun 2014 19:31 #24221 by aMax
Output currend up to 1A. That should be enough
www.advanced-monolithic.com/pdf/ds1117.pdf
24 Jun 2014 19:45 #24222 by aMax
@Arakon
Sorry, this might be good for Arduino projects, but not for RC planes/copters.
Range too low.You better take a modul of a V911_TX or buy something like
the A7105 DO3 modul.
www.banggood.com/XL7105-D03-A7105-Modifi...Flysky-p-922603.html ( no antenna)
I use this.
www.banggood.com/A7105-Wireless-RF-2_4GH...Module-p-909404.html
Looks the same but who knows.
24 Jun 2014 19:48 #24223 by Fernandez
But the 1117, dropout voltage is 1.1V so it means, 4x NI MH battery must be above 4.4V. But 4.4V can be considered as empty.
I'll order the module from BG
24 Jun 2014 19:54 - 24 Jun 2014 19:55 #24224 by aMax
It is even good for you cells not dropping the voltage to much.
With my NiMH cells i stop at 4.4V alarm.
Last edit: 24 Jun 2014 19:55 by aMax.
24 Jun 2014 20:20 #24225 by Arakon
aMax wrote: @Arakon
Range too low.
I use it only for the Hubsan X4, and that is so small that it's out of (usable) sight before it gets out of range even with the basic module.
I've flown it outdoors within usable distance and usually just fly it indoors.
Time to create page: 1.487 seconds
