Multiple Throttle Hold switches
14 Apr 2014 07:22 #22392 by cocozozo
Multiple Throttle Hold switches was created by cocozozo
Hi everyone,
Just added 2x 3 switches to my devo 7e and I have a question RE throttle hold.
Can you assign two switches to the safety function? (e.g. on a 3 way switch assign A1, and or A2 to hold).
Cheers
George
14 Apr 2014 08:03 #22393 by Daryoon
Replied by Daryoon on topic Multiple Throttle Hold switches
Should be possible with a mix.
14 Apr 2014 08:59 #22397 by cocozozo
Replied by cocozozo on topic Multiple Throttle Hold switches
Hmmm... I've had a look online and been unsuccessful setting it up so far (still learning). My models are based on Tom Z walkera models online.
Any chance I can upload for you to take a look?
(at work at the moment).
Cheers
14 Apr 2014 12:40 #22400 by cocozozo
I've attached a copy of my model if you would be so kind.
Basically I have it setup on my deco 7e so that:
original hold switch = ELE
3 way switch = position 2 is throttle hold (A1), would like position 3 for throttle hold also (A2)
2nd 3 way switch is for flight modes (B1, and B2).
original fmod switch = AIL.
14 Apr 2014 14:46 - 14 Apr 2014 14:54 #22403 by Tom Z
Replied by Tom Z on topic Multiple Throttle Hold switches
This should work. I added an extra mixer for Throttle Hold for SW A2.
Throttle Hold = SW A1
Throttle Hold = SW A2
File Attachment:
File Name: model1v2.ini
File Size:2 KB
* Rename the model. I added v2 to it.
Last edit: 14 Apr 2014 14:54 by Tom Z.
14 Apr 2014 19:02 #22412 by FDR
Replied by FDR on topic Multiple Throttle Hold switches
cocozozo wrote: Hi everyone,
Cheers
George
You can simply set the safety switch to !SWA0, i.e. NOT SWA0...
15 Apr 2014 13:21 #22420 by cocozozo
Thank you so much guys... Both methods worked perfectly...
Although I did end up using mixers with throttle hold a1 allowing for swash control and throttle hold a2 zero degrees pitch.
Amazing help...
B)
Time to create page: 0.420 seconds
