what antenna nrf24l01
- youri
28 Apr 2014 20:27 #22775
by youri
what antenna nrf24l01 was created by youri
Hey guys,
I have ordered a devo 10 and this nrf24l01 module
www.banggood.com/2_4GHz-NRF24L01P-+-PA-+...le-V3_1-p-88956.html
The only thing I am wondering is what antenna I should order and what antenna extension cable I should order?
Thanks for your help,
Youri
Youri
- SeByDocKy
28 Apr 2014 21:00 #22776
by SeByDocKy
Take this cable ...
www.banggood.com/SMA-Male-To-Female-1_5m...-RG316-p-923073.html
After drilling a small hole into your devo to install the SMA connector, you will be able to screw any antenna with male SMA connector such as :
www.banggood.com/2_4G-3-Leaves-Omnidirec...smitter-p-76956.html
W type SMA connector for example
Replied by SeByDocKy on topic what antenna nrf24l01
youri wrote: Hey guys,
Youri
Take this cable ...
- youri
28 Apr 2014 21:07 #22777
by youri
Replied by youri on topic what antenna nrf24l01
Thats what I thought aswell. the description says sma connector, but the picture looks like a rp-sma connector.
- victzh
29 Apr 2014 00:04 #22783
by victzh
Replied by victzh on topic what antenna nrf24l01
Or you can desolder the connector, get a piece of thin 50Ohm cable, solder it directly to the place where connector was, then bare the last 31mm of the cable (take off outer copper shell, leave alone inner insulation and wire) to get 2.4GHz antenna.
But good to know that circular polarizing antennas are available at Banggood.
- SeByDocKy
29 Apr 2014 05:58 #22786
by SeByDocKy
Yes... Now I am using them. I find it's more efficient for treeriding. I also installed a 2.4G RX antenna on the quad too.
Jacky from BG will also stock the 2mm pins headers so all material required to build the MM can be find in the same place
victzh wrote: Or you can desolder the connector, get a piece of thin 50Ohm cable, solder it directly to the place where connector was, then bare the last 31mm of the cable (take off outer copper shell, leave alone inner insulation and wire) to get 2.4GHz antenna.
- HappyHarry
29 Apr 2014 16:44 #22789
by HappyHarry
Replied by HappyHarry on topic what antenna nrf24l01
this is the antenna i use on both my nrf24l01 and my a7105-500 modules and it works perfectly
hobbyking.com/hobbyking/store/__16666__F...r_antenna_15_cm.html
- timmyd463229
15 May 2014 13:54 #23259
by timmyd463229
Replied by timmyd463229 on topic what antenna nrf24l01
I want to get the Nrf module but I'm not sure how do you connect the antenna to it and does the antenna stick out of the TX or just tuck away on the inside ..I ordered a devo 10 but don't have it yet
- what antenna nrf24l01
