How to change 22 / 11ms frame frequency on RX1202
01 May 2014 09:35 #22827 by lcn
Hello
My RX1202 has frame frequency set to 22ms by default.
How could i change it to 11ms ?
Is 11ms setting compatible with DJI Nava v2 ?
Many thanks for your help,
01 May 2014 09:53 #22828 by lcn
I finally found how to proceed :
11 Millisecond frame rate : for digital servos ( Green light on RX1202 )
22 Millisecond frame rate : for analog servos ( Red light on RX1202 )
After binding completed and RX powered on :
Press & hold the switch for approx 5s / 6s
Both indicators will turn on.
Release the switch & press it again :
The frame rate can be changed alternatively : the LED will turn red or green only depending on frame mode selected.
Time to create page: 0.111 seconds
