Confusing instructions on wiring for XL7105-D03
13 May 2014 20:13 - 13 May 2014 20:14 #23203 by AtlasAxe
I was looking at PhracturedBlue's module list page and it has two conflicting directions on wiring. In the table, it says:
Connect 6->9 and 7->8
Directly under the module's picture lower on the page it says:
Connect 8->GND and 9->3.3V. Leave 6 and 7 floating
Both indicate this applies to 4.0.1 and earlier. The illustration would imply that the first (6->9, 7->8 ) is correct, but I've seen pictures of the second online. Which is correct?
Regards,
Dennis
Last edit: 13 May 2014 20:14 by AtlasAxe.
13 May 2014 20:49 #23208 by PhracturedBlue
Replied by PhracturedBlue on topic Confusing instructions on wiring for XL7105-D03
The table says:
(*) - Denotes that alternate connections are required for Deviation 4.0.1 or below. See Module section below for more info
That means you need to use something different from the table for 4.0.1 or earlier, and that those alternate instructions can be found below (in the image section)
So:
newer than 4.0.1: 6->9, 7->8
4.0.1: 8->GND, 9->3.3V
13 May 2014 21:00 #23210 by AtlasAxe
Thanks PB, I get it now. I just read it wrong.
Would nightly builds be considered later than 4.0.1? I see they are designated 4.0.1.91307. I was guessing it is considered 4.0.1.
What will be the advantage to the new configuration when it's implemented in code?
I believe I understand the current 4.0.1 configuration - it turns off the receiver on the module, correct?
Regards,
Dennis
13 May 2014 21:53 #23213 by PhracturedBlue
yes nightly builds are considered newer than 4.0.1
The main advantage is the ability to turn on the receiver, which otherwise is disabled. Currently that only affects telemetry on the Hubsan X4, but who know what we'll see in the future.
13 May 2014 22:08 #23214 by AtlasAxe
Great, thank you again!
Time to create page: 0.129 seconds
