DevoDfuSe Tool 2.0
18 May 2014 18:20 #23319 by SkyKraken
DevoDfuSe Tool 2.0 was created by SkyKraken
The Walkera site seems to be down, is there another place to get the upgrade software DevoDfuSe 2.0?
And the Deviation release for Devo 8 and 8s are the same?
Is there a way to export and save what I have on my 8s radio before I move to Deviation?
18 May 2014 19:12 - 18 May 2014 19:15 #23320 by Fixy
Last edit: 18 May 2014 19:15 by Fixy.
19 May 2014 01:18 #23325 by SkyKraken
Replied by SkyKraken on topic DevoDfuSe Tool 2.0
Thank you kindly, Fixy!
Is there a special release for 8s vs 8, I've searched and read the documentation, and its probably obvious once you know, but when you don't know the difference between 8 and 8s, its a question hard to grep for.
19 May 2014 02:29 #23327 by PhracturedBlue
Replied by PhracturedBlue on topic DevoDfuSe Tool 2.0
The 8 and 8s are the same. You just won't have access to telemetry if you have a Devo8. you also cannot use the 'J6Pro' protocol with the Devo8 (unless you install the telemetry module)
19 May 2014 02:50 #23328 by SkyKraken
Thank you.
Is there anyway to save what I have, or should I even worry, not having access to Walkera to get a replacement of what I have, if things go wrong, is a little worrisome.
And the settings for models, I assume get clobbered and I just rebuild them in the new Deviation. right.
19 May 2014 04:04 #23330 by PhracturedBlue
On the Devo8 (and Devo10) Deviation will not modify your Walkera models. If you ever put the old firmware back they'll still be there. that is not true for the Devo12 (and I don't recall what we did for the Devo7e). However, if you want to back up your models, the DFuse tool will allow you to do that by selecting the 'Config' tab, and selecting the 'Number' of the model you want to save. Make sure to use 'Upload' and not 'Upgrade' when downloading models from the Devo transmitter.
19 May 2014 07:33 #23339 by SkyKraken
Thank you, I am now a Deviation convert. :woohoo:
The help is greatly appreciated.
Time to create page: 0.123 seconds
